ACTIVITIES PAGE - a guide to getting started
Please note!
The UI was recently changed, so a number of features mentioned below need to be updated. This guide will be updated during the course of 2025, as and when time allows.
In the guide, you will learn about the Activities page, and the features available.
Each section is covered in a separate post, so that any features relating to the specific section on this page can be updated accordingly.
The latest display, with new features added (No. 16-22) since this page was initially created.
Dark:
Light:
What can you do on this page?
  • Plan workouts, rides, runs for a day, week, block, year, etc.
  • Upload activities
  • Plan weekly training load, duration and distance, but sport
  • See a weekly summary of your wellness and activities, as well as weather forecasts
  • Add notes about holidays, illness, injuries, A, B or C events
  • Add to a list of races, or select existing races from a list
  • Add weekly notes (right side)
  • Edit route information
  • Contact coaches affiliated with the site
  • Take a screenshot of your current view
  • Get help for the page.
  • Bottom left is option to switch between light and dark
Thread Contents / Shortcuts:
Section 1
View the calendar by current month, past or the future
  • Clicking on the date, Aug 2022, opens up the next 2 weeks on the calendar, or you can select years and months from the past.
  • Clicking a year, eg. 2018 will then show January to December of that year below the 2018 date.
Section 2 and 3
Calendar view - the default view when opening the Activities page.
Clicking the List view, right image, it shows a list of your activities.
This allows bulk editing of certain data, by ticking the checkbox, left most column, and then using the Edit option. Editing allows:
  • Changing weight, FTP, W’ (pronounced double-u prime);
  • Fixing Heart Rate, Power, and/or cadence;
  • Re-detecting intervals;
  • Reprocessing the original file (excluding Strava);
  • Updating zones (useful if you forgot to change your LTHR, maxHR and/or FTP;
  • Delete activities
When selecting either of these options, the date range selector shows.
Section 4
Add entry to the calendar
Click the add entry icon, and you have the following options:
1. Wellness Data
Options to add a wealth of information relating to Wellness.
This will be covered in a separate help section.
The following entries are similar, and follow a similar screen layout. This will also be covered in separate help sections, eg. using the workout builder, or just basic details.
2. Ride (based on your list of sports in settings)
3. MTB (based on your list of sports in settings)
4. Gravel Ride (based on your list of sports in settings)
5. Run
6. Weight Training
7. Walk
8. Other workout
9. Paste
10. Search - races and events
The following entries allow a title, description, start and end date and a colour.
Most of this information appears as a note on the calendar, and covered under point 10.
11. A Race
12. B Race
13. C Race
14. Notes
15. Holiday
16. Sick
17. Injured
18. Season
18. Set eFTP
Allows to set the eFTP for a specific date.
19. Fitness Days
The default values for Fitness (42 days) and Fatigue (7 days) can be changed here.
20. Set Fitness
If you don’t have ride history uploaded to your calendar, but want to start from a known fitness level, you can add a start number for Fitness and Fatigue for a specific date.
Section 5
Workout Library
If your library is empty, you will see a blank pop-up lists as follows:
Clicking NEW allows two options, Plan or Folder
1. Plan
Give the plan a Name, eg. Season 2022, then the start week.
Rollout offers options to send to your calendar in blocks ranging from weekly, to the next 1-12 weeks, or the whole plan.
Auto rollout is disabled by default, but can be done on a specific day of the week.
Starting Fitness and Fatigue as well as a description can be added.
2. Folder
Adding a folder is useful to keep separate athletes apart, as well as specific types of workouts, or plans.
If your library has data it will show folders and plans
Files are stored on top of the library, while plans appear below.
The value in brackets indicates the number of workouts in the folder/plan.
Library folders shared with others will have the shared icon
The triple dot icon, far right, opens up more options.
Triple dot options
Options available are:
Add, Import workouts, Edit, Share or Delete the folder and Download.
Download options currently available are ZWO (Zwift), MRC (% of FTP), ERG (Target Power) or JSON.
The tick box, Copy when dragging is useful when adding the same details to more than one calendar date, eg. Planned Rest Day notes can be added to multiple days.
The search bar, at the top of the Library pop-up box, allows to search for a workout, eg. 4x4 reveals the 4x4m workout files with that name.
Using the PLAN to auto fill onto your calendar:
  • Name the plan
  • Select the start week
  • Rollout the whole plan or by weeks
  • Auto rollout can be any day of the week
  • Starting Fitness and Fatigue can be found on the FITNESS page, or from another PMC chart if you’re migrating to Intervals.icu
  • Description is exactly that: as simple or detailed as you see fit.
DELETE will delete the plan
CANCEL will close without saving
OK will close and save
2. ADDING TO THE PLAN
  1. The name of your plan; you named it in the steps above
  2. Actions allows you to hide/show all workouts.
  3. The athletes that this can be rolled out to. It can be yourself, or others. Simply tick each person in the list.
  4. Races can be added to the plan, which allows easier visibility of races within the plan.
  5. Adding from the library, is easy with drag and drop ability.
  6. Ask a Coach is also available.
  7. The same view as a calendar is showing in the plan, with summary information on the left block, daily workout view and the weekly summary notes on the far right.
CLOSE (top right) will close the plan.
Section 6
Ask a coach for help
This option opens a pop-up for you to contact affiliated coaches.
Section 7
Options
Quite a lot of features here, so updated posts will be required. Updated in Sep-2026 for Desktop View.
Open Customize
Select Customize in the upper-right corner of the calendar. The settings panel opens beside the calendar and can be pinned or closed from the upper-right corner. Its navigation is divided into Calendar, Data, Edit Layout, and Actions.
Calendar settings
Display: Controls the general calendar view. Options include commutes, the following week, inverted calendar order, multisport grouping, minimal mode, the fitness chart, source information, compliance, deleted activities, the coach’s tick, and the notes column. Select a checkbox to show the item and clear it to hide the item.
Filters: Enables saved filters and activity-shrinking rules. Use the checkbox to enable or disable a rule and the arrow beside it to select or edit its configuration.
Availability: Defines when training is possible for each weekday. Expand a day with the arrow on the right and enter the applicable availability. The configured value is shown in the weekly overview.
Data settings
Wellness: Select which wellness fields appear on the calendar. Optional CSV settings can include fitness values or all available columns. Use Download CSV to export wellness data and Upload CSV to import it.
Plan: Controls how the training plan is shown on the calendar. Enable Plan to display planned workouts, optionally show the plan name, and enable Show past planned workouts to retain previous planned sessions. Use Email to share the plan or Delete to remove it.
Calendars: Connects external calendars and training programs that support calendar export, including Google, Microsoft, and Apple calendars. Select Add Calendar to connect a calendar or Export Calendar to make the training calendar available in another supported application.
Edit Layout
Totals: Configures the weekly summary. Totals can appear at the top and include fitness, sport totals, custom chart values, planned work, progress bars, compliance colours, and zone information.
Custom chart values: Select the values that are shown as additional plots in the calendar. Each selected field creates a separate plot and can be configured individually. Open a plot’s settings to define its icon, label, and units, choose the weekdays on which it is displayed, and specify whether it appears in the Week Summary. Select All to show the plot on every day, or select individual weekdays as required.
Sport Settings: Configure the calendar card separately for your choosen activity types. Choose the card colour source (colour, intensity, RPE, or load) and select the values to display. Additional options can shrink warm-up, cooldown, and commute entries.
Weather: Adds weather information to the calendar.
Edit Layout: Opens the calendar-layout editing mode.
Use the controls that appear directly on the calendar to adjust the corresponding sections.
There are seven edit icons showing, when edit layout is selected:
  • 3.1. Totals - same as Customize → Edit Layout → Totals:
  • 3.2. Fitness Plots - see this post for more information to add these “metrics” to the calendar. same as Customize → Edit Layout → Custom chart values:
  • 3.3. Totals - this is the same as 3.1, above.
  • 3.4. Wellness data - select fields to display in the calendar, as well as options to download/upload CSV data. Same options as Customize → Data → Wellness
  • 3.5. Fitness Plots - this is the same as 3.2, above.
  • 3.6. Weather - allows you to set single/multiple weather stations on the calendar. Same options as Customize → Edit Layout → Weather
  • 3.7. Sport Settings - allows customisation of one/more sports. This section might require a help section on its own. Same options as Customize → Edit Layout → Sport Settings
Search and CSV export
Select Search in the calendar toolbar to open the activity search. Enter an activity name or another identifying term in the search field. Select Download CSV in the same panel to export the activity data.
Section 8
Upload
Clicking on the Upload button allows you to upload any activity to your account.
Drag and Drop, or click to select a file from your computer’s folder(s).
Section 9
Option to go to a specific date.
Click on the grey block, eg. AUG 29, it will open up the next 2 weeks on your calendar.
On the calendar, the past is below the current week, while the future is above. There have been requests to swap this around, similar to other apps, but it’s currently hard-coded as current.
Repeated clicks on the date bar, will open up the next 2 weeks on each click.
Section 10
Notes section
If notes are loaded for 2 or more days, they will appear above the week, eg. Base3 (red) and Test note (green) appear in week 32.
This applies to Notes, Holidays, Sick, Injured and can be custom coloured for easy identification.
Clicking on the note allows you to delete, mark done, edit or simply close the notes.
In addition to the single day or multiple day notes, the weekly notes allows a view on the right side of the screen.
Section 11
Weekly totals
This section can be viewed across the top of week, or to the left.
Change this in the Options menu (section 7) by ticking the option Show weekly total on top depending on your preference to view information on screen.
What can be viewed in this section? From left to right:
This is the view when Show weekly total on top is selected
  1. Week dates, Monday to Sunday
  2. Week number
  3. Total Training Load
  4. Fitness
  5. Fatigue
  6. Form
  7. Ramp rate
  8. kcal for the total workouts
  9. Elevation gain
    10a. Biking specific target load, duration, distance and %compliance
    10b. Running specific target load, duration, distance and %compliance
    10c. Swim specific target load, duration, distance and %compliance
  10. Training Intensity Distribution, eg. Polarised, Pyramidal, Threshold, HIIT, Base or Unique.
  11. Time in zone distribution (power or HR, depending on your selected option in the calendar).
This is the view when Show weekly totals on top is not selected.
Clicking on the weekly summary, the following view is shown with additional options and information:
  1. Graphical view of time in zone
  2. Training Intensity Distribution (the type is slightly bigger)
  3. Summary information below (Fitness, Fatigue, Form, Ramp Rate, Weight, eFTP and FTP/Kg
  4. Options to add Planned data for Biking, Running and Swimming (top right).
Clicking on Biking will allow the following options:
For week 32, you can add the planned Training Load, Time or Distance as well as a note.
Your progress against the plan will be viewed in the weekly summary, eg. 121%
Section 12
Wellness & Weather information
This section will only cover Wellness information. The weather information is discussed in section 15.
The information appears in order, from top to bottom, as follows:
  • Date
  • Weather information (today + the next 13 days in the future).
  • Wellness information
    • Sleep data, Weight and Hydration
    • HRV data
    • Subjective feeling, eg. Soreness, Fatigue, Stress, Motivation and Injury.
1. WELLNESS INFORMATION
Clicking on the date will allow you to add an entry. Besides workouts and activity data, you can also add Wellness Data
Here you can add (left to right, top down):
  • Weight and kCal Consumed
  • Resting HR and Sleep duration
  • Sleep Score and Average Sleeping HR
  • SpO2 (Oxygen Saturation) and HRV (rMSSD)
  • HRV (SDNN) and Readiness score
  • Baevsky SI and Systolic blood pressure reading
  • Diastolic blood pressure reading and Blood Glucose level (mmol/L)
  • Lactate (mmol/L) and Hydration (L)
  • Body Fat % and Abdomen (cm), aka the waist circumference
  • VO2max score
Below that, you have the 1-4 rating for the following:
  • Sleep Quality
  • Soreness (Pre-training)
  • Fatigue (Pre-training)
  • Stress
  • Mood
  • Motiviation
  • Injury
  • Hydration
Lastly, a space for comments
Fields is a dropdown menu that allows you to select what information you want to see on the activities page. Simply tick/untick the options
OK & NEXT will take you to the next day’s entry, so you don’t need to close, go to the next day and open the menu again.
CANCEL simply closes the page without saving
OK saves and closes.
2. DISPLAYING THE INFORMATION
On the calendar page, for one day, it can show you the summary information in graphic/numerical form at the top of the day’s entry.
  • Date: Mon 15 Aug
  • Sleep duration: 7h58m
  • Sleep Score: 5
  • Sleep Quality: Q3
  • Hydration: Ok (Hydrated)
  • Weight: 80Kg
  • Resting HR: 44
  • Readiness: 9.2
  • HRV rMSSD: 111ms
  • HRV SDNN: 115ms
  • Mood: Good (the black smiley)
  • Soreness: 1 (low)
  • Fatigue: 3 (high)
  • Stress: 2 (average)
  • Motivation (to train today): 2 (high)
  • Injury: 1 (none)
Most of this data comes from the HRV4Training app that I use every morning.
More information about HRV can be found here.
If this data is missing, it’s not completed, or the upload from HRV4TRaining via Dropbox hasn’t been done. Not all the scores are completed in HRV4Training, eg. Weight, Stress, Mood, Injury and Hydration. This could come from other sources, or simply completed on the Wellness pop-up (section 12).
Section 13
Planned and Actual Ride data
This section view will change depending on the setting you have chosen in OPTIONS (section 7).
The default view (for me) is Compact, and if I want more information I will click on the workout to see the more detailed view.
So let’s look at one day, and the information you can see:
RIDE SUMMARY - with colour bar
The next section shows the ride plan, as well as ride data (if completed). It could also be blank, or it could show notes. Below represents a ride with a paired workout:
This will change depending on the view selected, eg. Normal, Compact and Minimal
The icon shows the activity type, eg. Run, Ride, Strength, Swim, etc.
Duration is next, in hours and minutes.
Distance is the on the right side of the colour bar.
The colours can be changed in OPTIONS (Section 7), as follows:
Options available or custom colour, based on intensity, RPE or Load.
There are custom settings options for Intensity and Load, whereas RPE is set at 1-10 only.
Further options allow you to tick (show) or untick (hide) the following options:
  • Ignore workout colours will use the default colour for the activity (see section 2&3 above).
  • Average Heart Rate & Intensity
  • Normalised Watts and RPE (Rate of Perceived Exertion)
  • Pace and Feel
  • GAP (grade adjusted pace) and Name (of workout)
  • Load and Intervals
  • Weight lifted and Description (of workout)
DEFAULTS returns the settings to the normal, i.e. no colour based on Intensity, RPE nor Load.
CANCEL closes and doesn’t save
OK closes and saves your changes
3. RIDE DATA
Clicking on the ride data opens the workout summary view, which will be covered in Section 16, below.
Depending on the view selected, you will see less/more information. In the Normal view, you will see:
  • Average HR: 146bpm, and Normalised Power: 242W
  • Load: 85
  • Intensity: 92%, RPE score: 10 and Feel: Smiley/Grumpy face
  • Intervals detected: 10s 402W and 30x 18s 485W
  • Activity Name: Evening Ride ~
  • Notes in the description: #3x10x20/40s AC sprints
  • Source file: Garmin Connect, Strava, Polar, Upload, etc.
  • Compliance to plan: 80%
    * Green tick: less than 20% above/below the planned load
    * Orange tick: 20-50% above/below the planned load
    * Red tick: greater than 50% above/below the planned load
  • Workout graphic, if you had a detailed workout, using the Workout Builder.
Section 14
Notes, and/or planned workouts with no completed workout
Occasionally, one would miss a workout and it would show the 0% compliance.
Notes made, as also showing in this section below the Weather, Wellness and Ride data.
Example of a Note for “A Planned Rest Day”.
Notes for a single day will be displayed under the workout, while Notes spanning 2 or more days will be displayed above the daily calendar entries (covered in section 10, above).
Section 15
Weather Information
Clicking on the weather information opens up a summary of the weather information for your chosen place. It is possible to have more than one location set, but does add more data to the day entry.
Other settings
Wind Speed can be set to:
  • mps (meters per second)
  • knots
  • km/h (kilometers per hour)
  • mph (miles per hour)
  • Bft (Beaufort Scale, 1-16)
Rain can be set to:
  • mm (millimeters)
  • in (inches)
Under OPTIONS (section 7) you can setup the weather for your preferred destinations.
Click on OPTIONS > Weather it will open this pop-up view:
  • Add Forecast allows you to browse for a location using the following options:
  • City (if known, it will prompt with the known city names)
  • Label (you can customise this to suit your preference)
  • Geographic co-ordinates, i.e. Latitude and Longitude (a Google search can assist with these numbers)
Examples of City names, with one or more options:
More than one destination can be saved, then you can tick/untick locations based on when you’re travelling.
Section 16
Workout Builder basics
There is a thread dedicated to the Workout Builder, but has a lot of comments in-between the vital information. This section will touch briefly on the basics:
Before starting, let’s understand what is displayed once the workout is ready to be saved.
  • Category: Chose from Workout, Manual Activity, A-B-C Race.
  • Name: 4x8m VO2 Max, can be anything you want** - this is a mandatory field.
  • Colour: Red default is red, but you can select from a list of colours.
  • Date: 19 Aug 2022, today’s date, or select a date if you’re working on another workout.
  • Time: 06:00, useful when doing more than more than one workout per day**.
  • Duration: 1h44m, an optional field; can be calculated if using the description field below**.
  • Load: 123, an optional field; can be calculated if using the description field below**.
  • Description: Custom text, duration, intensity, cadence, etc will show in the graphic at the bottom of the pop-up menu
  • Time in Zone (TIZ): if Power/HR and Duration is used, it will show the TIZ to the right:
    • Z1: 32m (30.8%)
    • Z2: 40m (38.5%)
    • Z5: 32m (30.8%)
  • Intensity: 84% (complex formula used to calculate this number).
  • Normalised: 221W, is the planned Normalised Power for the workout**
  • Average: 189W, is the planned Average Power for the workout**
  • Variability: 1.16, is the planned Variability (NP/AP) for the workout**
  • Work: 1181kJ, is the amount of total work done (1kJ = 1000Ws).
  • Work>FTP: 553kJ, is the amount of work done above the set FTP.
Click on the day for the chosen activity, then select the workout type, eg. Run, Ride, Swim, etc.
HEADER SECTION
Enter the workout description, eg. 4x8m threshold
The colour can change based on your preference.
The date can be changed if you clicked on the wrong day when adding the entry.
An optional time can be used
Type: Ride, Run, Virtual Ride, Swim, etc.z
Duration and Load can be entered here, if known, or the steps in the next section can calculate it for you.
WORKOUT SECTION
There are two ways to build a workout:
  1. Learning the code/lingo used
  2. Using the ADD STEP method
WORKOUT SYNTAX - Updated on 06/01/2025
*Workouts need to be in the same unit of measure, eg. all power, all HR, all pace, and not a mix of units. Additional information can be added, eg. text, duration, intensity and cadence (optional).
Clicking on ADD STEP opens a user-friendly prompt, which is divided into 10 sections. The category will be Workout (default setting):
A detailed description of each follow this, and the example of one line of text.
  1. Interval Type
  2. Duration
  3. Distance
  4. Target control is Power
  5. Target control is HR
  6. Target control is Pace
  7. Target control is Cadence – this would complement power, and not standalone.
  8. Power type (% of FTP/MMP, absolute, or a range of each option)
  9. Custom Text
  10. Intensity description (warmup, active, interval, cooldown)
The combination of these options (listed above) will show in the Description area of the calendar entry.
  1. TYPE OF INTERVAL – select from these options. This applies to Power, HR and Pace:
    a. Normal – the default setting, eg. 10m 40% (power) and 10m 40% HR (heart rate).
    b. Repeats – adds the line 2x, 3x, 4x, etc. 3x repeats
    c. Ramp – a gradual increase from one value to another value, eg. 40-70% (of FTP), or Z1-Z3 HR (of maxHR).
    d. Warmup – adds the word warmup, plus and duration, intensity and text.
    e. Cooldown – adds the word cooldown, plus any duration, intensity and text.
    f. Freeride – when a prescribed power level is not required, eg. the 20-mins of the traditional 20m FTP test. Think of the Zwift test, where there is no power guiding you along. Similar for HR, where a target is not necessary.
    g. MaxEffort – used to indicate an all-out effort that might not have a target value set, but rather indicative.
  2. DURATION
    Expressed in three units or time, namely:
    a. h = hours
    b. m = minutes
    c. s = seconds
The format can be written as a singular unit only, or as multiple units, as the examples below show:
• 45s = 45 seconds
• 90s = 90 seconds
• 1m30s = 1 minute and 30 seconds (which is also 90 seconds)
• 90m = 90 minutes
• 1h30m = 1 hour and 30 minutes (which is also 90 minutes)
  1. DISTANCE
    a. Can only be used in Km
    b. Used in conjunction with Pace (please correct me, if wrong, as I don’t use this field).
    4-7. Unit of measure need to be the same, eg. all power, or all HR, from the following options:
  2. POWER
    When using Power, there are ways to measure the power relative to a known value/range, eg. %FTP (80%), %FTP range (Z1-Z2):
    a. None – lists as the duration entered, eg. 5m
    b. % FTP – a fixed % of your FTP, eg. 80%
    c. %FTP Range – a range of % of your FTP, eg. 70-80%
    d. Zone – Z2
    e. Zone Range – Z1–Z2
    f. %MMP – a fixed % of the MAP value on the Power page, eg. 100%
    g. % MMP Range – a range of % of the MAP value on the Power page, eg. 90-100%
    h. Watts – a fixed value, eg. 300W
    i. Watts Range – a range of watts, eg. 295–305W
Once selected, there are a number of sub-options (targets) to choose from, depending on the unit of measure selected, eg. using target power (Garmin only) has these options:
• Lap Power is the lap average, and has no specific text. It changes when a new lap is activated.
• power=1s Instant Power (current power, that changes every second)
• power=3s Power (3 second average)
• power=10s Power (10 second average)
• power=30s Power (30 second average)
  1. HEART RATE
    When using Heart Rate, there are ways to measure the HR relative to a known value/range, eg. %LTHR (Lactate Threshold Heart Rate), %MaxHR (Maximum Heart Rate). These need to be setup in settings, if not already done:
Note: When using HR as the target, it has to show HR or LTHR after the options (below), otherwise it defaults to Power, eg. 80% HR is 80% of maxHR, and 80% LTHR is 80% of LTHR.
b. % MaxHR – a fixed % of your maximum HR, eg. 80% HR
c. %MaxHR Range – a range of % of your FTP, eg. 70-80% HR
d. %LTHR – a fixed % of the LTHR value on the Settings page, eg 100%
e. %LTHR Range – a range of % of the MAP value on the Settings page, eg. 90-100%
f. Zone – Z2 HR
g. Zone Range – Z1–Z2 HR
Once selected, there are two sub-options (targets) to choose from For Garmin only), which is Instant HR (beat by beat change) or Lap HR (average for the current lap.
  1. PACE
    When using Pace, there are ways to measure the Pace relative to a known value/range, eg. %Pace (80%), %Pace Range (80-90%). These need to be setup in settings, if not already done:
    b. %Pace – a fixed % of your threshold pace eg. 80% Pace
    c. %Pace Range – a range % of your threshold pace, eg. 80-100% Pace
    d. Zone – a fixed zone (as per your pace settings on the Settings page), eg. Z1
    e. Zone Range – a zone range (as per your pace settings on the Settings page), eg. Z1-Z2
  2. CADENCE
    a. Used in conjunction with Power (cycling) as a target cadence value.
    b. RPM is the unit of measure, i.e. revolutions per minute.
    c. Can be one value, eg. 100rpm or a range, eg.100-110rpm
  3. INTERVAL INTENSITY – each selection (4-7, above) has sub-options to choose from.
  4. Custom TEXT you can display on the device (GPS) or on screen, eg. Zwift, TP Virtual, etc.
    Example = high cadence, low force
  5. INTENSITY - select from the list,or use Auto (default):
    a. Auto (doesn’t show intensity=xxxxx)
    b. Active, intensity=active
    c. Interval, intensity=interval
    d. Rest, intensity=rest
    e. Recovery, intensity=recovery
    f. Warmup, intensity=warmup
    g. Cooldown, intensity=cooldown
    h. Other, intensity=other
I’m struggling to see where to change the time in zones on the Calendar page to HR. Can anyone help? Many thanks!
In settings, you set the priority to determine load. Based on that selection, the TIZ in the summary will show.
Awesome! Many thanks for coming back to me so soon.
[quote=“discobot, post:13, topic:36368”]
discobot
[/quote
@discobot
