Mobile App for Intervals.Icu (BreakAway: Indoor Training iOS)
Thanks for the bug report! Appreciate it… since i don’t have all sort of devices (ios versions) to test on.
Hmm… the code for completed time in Power Zone is same for both versions… Let me check. but will fix
to confirm… this is version 65.1 from the App Store right? (or rather, latest from the app Store)
@zt_zzz would you mind checking out the BETA app if this issue still exists?
I see notes on my version that shows I’ve fixed something so that the bars doesn’t get compressed.
Join the BreakAway: Indoor Training beta
This Beta app would also let you preview some of the updated integration.
Tx
yes
It‘’s perfect if can be solved easily, but it doesn‘’t affect the function of the app。 :grinning:
Thank’s ,I have installed The Beta app。
will b fixed…look nice it must
pls try the beta if can.. :folded_hands:
Suggestion for the new version:
Before save the end of training, can you add an option: again
That is to say, one more time!
Because the difficulty of training:2X30Min Z2<60Min Z2(psychological reasons :sweat_smile:
Sometimes the training duration cannot be determined.Maybe 30Min 1h 1h30min or 2h …4h…
but 2X30min=1h or 2X1h=2h
The change may be very big,You’ve had a long flight.
When I schedule a session that I might not know if I would do 30m or 1h or 2h, I would create the session as 2hr and then use the “>>” button to fast forward to the last interval (warmdown).
This might also work for you on those sessions.
I see you mentioned that you installed the beta. does it look ok?
TX
The beta app is in use.
Sometimes i will train for 2 hours or more, but if the training is set to 3 hours, the psychological pressure will be greater
This image is N *30Min 70%
6h
Some Updated Screenshots. Now you can
  1. Edit the workout Details
  2. Add Self Evaluations for RPE and FEEL
  3. Delete Workout from Intervals
  4. Moved the “Open In” to a smaller menu
  5. Pair / UnPair Workouts
  6. Add in Race/Commute/Trainer “Labels”
I’m still looking for Weight Training, I see there’s one field called “Weight Lifted in kg” Havent found out where this value exists in the API.
Hi
Are there any plans to develop an Android or Windows version of this app? Sounds great and exactly what I would be looking foe to supplement the Wattbike Hub workouts.
Sam
Thanks for taking a look. At this current juncture, the answer would be a No.
It’s a definite No for Windows for sure, android is a KIV for future.
Hi @app4g ,
How can make BreakAway to import a workout with cadence and without power? Check the high cadence blocks below
App shows a popup:
Thank you!
Tito
This looks like a Garmin HeadUnit workout as there are no power numbers for that high cadence block.
For indoors, typically there would be some default power in ERG / Resistance / Slope Mode. BreakAway would not know what to send the the Trainer when there is no Power/HR/Slope targets and currently, i only send a 30% of FTP during Free Ride mode if no initial power is provided.
For your case, I would suggest putting in a default power percentage. It can be any power number eg: 30%
It may be possible for me to add a default 30% of FTP to the import script when no power is detected, but I’m afraid that would have unintended conseqeuences for some % of users
(eg: Once added 30% to the high cadence blocks)
ps: new rev of BreakAway will also pull in cadence targets
Thank you very much! It worked… :+1:
I’ve added Additional capability when using the Intervals.icu activity edits. YOu can now selectively sync edits back to Garmin Connect.
More here..
Added a new Splits/Laps data quick look.
Will be rolled up for next official release
updated look of calendar with support for Completed workout Skyline Chart (newest feature from intervals.icu) and now also with Zone Colours. All in sync with Intervals.icu colour schemes (only for 7 zones Power Scheme)
Add HR/Power/Cadence/altitude charts.
Same like
Two situations:
First, if I bought the 1000 coins package, why do I continue to see advertising?
Second, it keeps giving a connection error, I’ve turned it off and on again and I can’t resolve it.
I noticed that as for being a betatester, it no longer appears active for me?
It does say that it doesn’t remove ads. Perhaps wait for the new (supporter) revision where there’s the option to remove ads all together.
I just tested mine and it’s working. Not seeing an error. . I’m not on the beta tho.
Are you able to get anything from intervals.icu? Does the sync work? Everything seems to be in order on my side as well.
Perhaps you can use the “LOGCLOUD” option and generate some logs? I will most certainly take a look at it.
As for the ads, Its still in my todo list to have a supporter tier and remove ads altogether. :folded_hands:
Tx
I was only able to access the forum today, I was away, I will test and send the data to see what could be happening, thank you
