Was this step needed previously? I know there’s a new FW on the newer watches which somehow makes 3rd Party CIQ stuffs not getting power data from the Stryd pods
Yes, otherwise you will get conflicting alerts for the run power workout
….thanks: I will…!
I tried, but the workout screen didn’t get any power from stride: I could see stride power on other pages, but not in the Garmin dedicated training page…
does it work the same for you…?!
That’s correct. The workout screen is not compatible with stryd and it can’t be removed. Simply ignore it. The stryd zones datafield handles the workout steps and alerts for you. Make sure it’s added as a full page data field
I’ll try tomorrow… thanks @zigford
Another vote for nested intervals! Seems like the future syntax could use parentheses or another symbol to denote nesting.
Here’s a workout I’m trying to build:
Main 3x
Sub1 10x
- 30s on Z4 HR
- 30s off Z1 HR
Sub2
- Easy 5m Z1 HR
Instead I’ll have to code it this way for now:
Sub1 10x
- 30s on Z4 HR
- 30s off Z1 HR
Sub2
- Easy 5m Z1 HR
Sub1 10x
- 30s on Z4 HR
- 30s off Z1 HR
Sub2
- Easy 5m Z1 HR
Sub1 10x
- 30s on Z4 HR
- 30s off Z1 HR
Sub2
- Easy 5m Z1 HR
By far the best builder I’ve used and maybe some of my questions/ideas are repeats
is there a way to have a workout library? Currently I’ll keep the descriptions in excel under tabs for endurance/tempo/threshold rides, but would be cool to be able to schedule them
When I duplicate a workout for the week ahead and then make changes to the second workout, I think it changes both. Is there a way to make it so you can choose to edit either that one workout or the entire series? Would be cool to schedule say vo2 for one day a week for the month and then edit each week for a higher % or shorter breaks
Keep up the amazing work
This create 2 diff workouts.
eg: i alt-drag from bottom to upper )dec 19) and then edited the copy. YOu can see there’s a difference in the workout graphic.
There’s a search function you could use as well.
I have tried to find this by searching the Forum, but failed to find an answer (possibly because non-Erg mode can have any one of a number of names).
Is it possible to define a segment or interval within a workout as a free ride (aka responsive mode) rather than specifying a power?
This wholly depends on what is your destination app / program / trainer that you are using.
For Zwift: You can use FreeRide
For Garmin HeadUnits:
I am not sure, but I do see this in the workout builder as option
If you’re using BreakAway, you can do switches to auto switch from ERG → RESIST /SLOPE Mode and vice versa.
hope that helps
Thank you, that was very helpful - I’m tweaking workouts and exporting them to Zwift.
Is it possible to add slope ? With freeride, I have 1% in IcTrainer (SIM mode). For some sprint, I would like to change for 6 ou 7%
Hello,
I usually receive my trianing plan in a way that at the same trainig both HR and power present like this:
- 15’ 50-55% HR
- 15’ 55-60% HR
- 15’ 60-65% HR
main set 2x
- 12’ 70-77%
- 8’ 50%
-20’ 45-50%
If I save the training in this way the HR range is not visible on my Garmin during the training, it just counts down the time without showing the HR zones but afterwards the power zones are shown properly.
How can the HR and Power zones combined in order to see both properly on my Garmin?
Thank you!
See this..
your workouts can be ALL power, All HR or All Power with some HR
If you don’t see the workout graphic, likely it’s not in the intended format
Is there a possibility to implement a „skip last step of recovery“-feature in the workout builder? Would be nice to go straight into the cool down step after the last effort of a 4x8 interval session for example. (3x 8min Z5, 3min Z1; then another 8min z5 and then straight into cool down) ![]()
Could anyone provide me some examples of workouts using Stryd power zones? I’ve entered my Stryd CP value into Intervals.icu Settings page under Running activity type and FTP field. But if I create a workout and check in Garmin it doesn’t show the power target range properly. Thanks.
it would be nice indeed!
I see the possible issue.
You’re mixing pace and hr in the workout.
Quick tip. If you see the graphic has some blanks like your screenshot. Means it’s not going to be supported.
