With regard to the syncing of the Intervals calendar to TP (option 1), i get an error that suggests i need a paid subscription to TP for it to work. Is that correct?
No, it’s not.
Syncing workouts for today and tomorrow is available for free TP account.
Could you tell me what date range you have in this section? Are these days in your case represent today and tomorrow?
This works great. Under advanced options is intervals.power-range used? I thought it might turn a single value power to a range of powers (which is nice when used w/ garmin).
I just didn’t implement steps with single value. All steps interpreted as steps with range, even if min and max and the same values.
Eventually, I think I will fix it.
I just got the payment error again when trying the TP sync. The workout is scheduled for today (29/3) on Intervals and the date range is correct in tp2intervals.
I assume it is a time zone issue. My time zone is UTC+12:00 Auckland/Wellington New Zealand.
I wasn’t able to reproduce the issue, but I found that somewhere I use date time instead of date. I fixed it.
If you still will have same issue. Go to Configuration, check Show advanced configuration, set log level to DEBUG, Confirm, reproduce the issue. Then send me log file (where to find logs) here via PM or directly to [email protected]
Hi, thanks for your work on this. I have over 3000 workouts in TP so pulling them/some across is of interest. I have a paid coach account and a free athlete account with TP.
The tp2intervals config saves. I get a green confirmation. Unfortunately, I then get the following error message (when I select TP in the top bar):
Error while extracting response for type [java.util.List<org.freekode.tp2intervals.infrastructure.platform.trainingpeaks.plan.TPPlanDto>] and content type [application/json;charset=utf-8]
Apologies I can’t find a log file. No tp2intervals folder in .config on Ubuntu 22.04.
When TP page is loaded, the app requests all training plans and workout libraries. Without logs hard to tell, what could be missing. I hope it’s description. I’m gonna take a look at it.
Added buttons Today, Tomorrow for quick workout planning in TP
Improved time to load platform pages
Fixed retrieving plans from TP without description
You can try the new version
I haven’t tested the app on such amount of workouts. My biggest plan has ~150 workouts, it took about 5-10 sec to sync. In your case to sync 3000 workouts can take…some…time. Just be prepared to wait about 3-5 min.
