Can you show me a screen shot of what that looks like on your activities page?
My understanding is if a day (lets say today) I have Wahoo and Strava BOTH send to Intervals - my intervals will double my TSS, Fatigue etc…
Is that not accurate?
Intervals.icu will de-dupe the data (based on workout time / duration etc etc) and will discard the Strava data (higher priority given to non-strava data) and you will only end up with 1 single workout.
UNLESS you are recording with multiple headunits. (Outdoors, I record w/ 2 head units and both data gets sent to Garmin + Strava and Intervals. I need to manually delete 1 of them. But the TSS etc remains generaated from 1 single workout
Hope that helps
OK that is cool.
Bandaid comes off this afternoon when I can monitor the progress
Stoke is medium-high today.
Alright - Un Ticked Strava Download Activities
Authorized Wahoo.
Selected Download Old Activities (Given the weighting pref shared by app4g)
Pre Wahoo Sync Fitness was 95.
We are now at 98. But there are 450 workouts that have to be pulled down.
Little bit of dark side of the moon now.
Waiting game.
Looks good! Thanks team!
Im also now getting some of the new fun jazz with L/R balance and the good stuff strava was stripping out!
Big win. Danke!
Note that I didn’t do this. I just “switched” over by adding Garmin. Thats about all I did. Just connect Garmin and have it download activities
this is the way…
Hi everyone!
I just created a new account and started syncing with both Garmin and Strava.
Since I wanted to have the full history, I also uploaded both dumps from Garmin and Strava and got covered from my very first activity.
My problem now is that I can’t find some of my activities by the name I’ve set on Strava but not on Garmin.
How can I handle this situation?
I read in some past replies that there should be a way of taking the Strava name and Garmin data, but how?
Thanks a lot!
P.S.: Is there any way of forcefully discarding “deleted” activities once and for all?
From my experience above with Wahoo - You should not discard anything.
As @app4g and @Nik_Om_Cinderella_Ri shared Intervals actually prioritizes non Strava workouts. But you can still have the title as it will “blend” the two.
See my screenshot below:
Ride title via Strava and on the right Wahoo and Strava.
But if you look at it on the activities page:
Its one single entry:
Though as I am about to hit the reply button:
If you want to search Intervals by strava title - I havent done that before.
I tend to look back on the activities page and the fitness page rather than remembering a semi-clever ride title.
In my case, it’s only marked as Garmin
What could be the reason? Does it make sense to upload just this Strava activity manually to see what happens?
To help we would need to see your “settings” page.
Should see something like this:
Note - I have both Wahoo and Strava download ticked.
Sure, here’s my setting page!
Reminder: that activity is from 2 years ago, and it was added through bulk import together with hundreds of other activities.
Ah - if its bulk that is outside my experience.
But my next question would be if you are a paid intervals member?
Wonder if this is a historical data thing that only syncs back 90 days etc.
Also what about more recent activities? Do you see both flags on current workouts?
fit
file, but what appeared then on the list was the previous Garmin versionStrava here means items from their API.
If it’s manual upload. You should see ~ Upload
The ~Strava link is just to send you to the Strava activitiy webpage. Other items are merged / prioritized with non Strava data. (So not violating Strava t&c)
It makes sense, in fact, all the Strava activities older than a few weeks are marked as “Upload” (since they were imported through the dump import). The curious thing is that that doesn’t happen for Garmin, meaning that the activities imported from the dump are correctly marked as “Garmin Connect”.
I double-checked the information instructions related to the import of old data for Garmin and Strava and noticed that Garmin limits the API import to one year, but that doesn’t apply to Strava. For this reason, I launched the old data import for Strava and it was able to process all the activities from the very beginning of my history.
As a consequence of this:
So, thank you very much, everyone, for all the hints, you helped me understand how this platform works!
Manual upload for Garmin probably doesn’t have as much impact as Strava (T&C wise)
What you get from Garmin Connect over the API is the original FIT file and that is ‘your’ data.
What you get from the Strava API, is a modified FIT and Strava considers that ‘their’ data. If you request your full archive, you are getting the original files and thus also ‘your’ data.
I am intending to drop Strava from my training ecosystem and source of data for intervals.
Current Setup:
Polar flow (Exercise) → Strava → Intervals
Trainerroad → Strava → intervals
Rouvy → Strava → Intervals
Polar Flow (wellness data) → intervals
New setup:
Polar → intervals
Rouvy → intervals
Trainerroad (unsubscribe)
My main question is if I disconnect Strava and add exercises to the polar import, will I lose my currently imported Strava exercises? and will I need to re-import them from Polar & Rouvy
you can find your answers above.
Doesn’t matter where is the org source.
Just remove “download activities” from strava
