I could do that as a step one, but what happens the day I close my strava account completely. I am no longer using it so have little need to keep it around
Would I then need to resync old sessions?
Once again, if you disconnect Strava, you loose all history from activities that came in through their API!
First request your full history and import that. After import you can disconnect because your original activity files are ´Uploads´.
This has been repeated numerous times nowâŚ
Its all in the above thread
Then this would happen and you will cry a little (or a lot)
then you do that.
