Select the items you want to download from Oura, click connect and authorise Intervals.icu to access your Oura data. Your complete history will be downloaded. After that the most recent week of data is downloaded approximately 3 times per day and when you visit Intervals.icu.
Items downloaded:
Sleep duration
Sleep score
Sleep quality (updated from sleep score)
Average sleeping heart rate
Resting heart rate
Readiness
This can be displayed on the calendar (Options → Wellness) and plotted on the /fitness page.
If you were testing this feature before, disconnect and re-connect to pickup the new fields (average sleeping heart rate).
I added a custom field for this and updated the Oura integration to populate it if it is present and HRV is enabled. You just need to add this to your wellness fields:
Hi David,
Firstly, thank you for this great app, I love it.
I just acquire an Oura ring and I wonder why there are differences between Oura data and the data uploaded in intervals.icu? Mainly sleep score, sleep time and readiness.
Are you sure that no other source is connected for wellness data?
If for example Garmin Wellness is also connected, the values displayed will be those from the last successful sync.
Check the settings page for Garmin Connect, Polar, Coros, Google Fit, whatever other connection you have.
Tx. For the 26th Intervals got “sleepSecs”:20970 which is 5h46m. I will add some more logging to see exactly what Oura sent. Maybe there are some extra fields.
And I am wondering if the sleep score matching is not a coincidence?
From Oura: date / sleep time / sleep score
2023-07-28 / 8h38 / 95
2023-07-29 / 7h40 / 71
2023-07-30/ 7h46 / 78
It’s not match with values from intervals.icu.
It’s not seem to be an error from your side but rather Oura side.
Am I the only one to notice these differences?
I use Oura myself and it’s always been fine and haven’t had other reports of problems. Did you perhaps connect an Oura account for someone else in your household who happened to be logged in?
