Import all data from Strava
I felt so good disconnecting Intervals from Strave. I also stopped their subscription a while ago and hopefully I will be able to stop using it completely. They need to be replaced by someone who is willing to play nicer and build the community as opposed to building moats.
Anyone can comment if the “download all data” is the original FIT file or the clobbered by Strava data fit file?
If it’s the original. Then it’s still a good archive right?
You get all the original files in that download and can do with them what you want. It is ´your´ data and Strava can´t limit anything on those.
Was asking cos @WindWarrior Was talking about TP free for archive purposes
I ended up with duplicate activities after an import, which feels like a bug. I think I understand what happened, and may be able to fix it programatically on my end, but it seems like it might be a general issue. So worth looking into probably.
My history goes like this:
  1. Imported data from Strava
  2. Added Wahoo as source through Dropbox
  3. Did an export-upload of Strava
After the Wahoo data, I got some matched rides where I had dual-recorded Zwift rides on my Wahoo headunit. These weren’t 100% matches obviously, but got matched as they should.
When I did the full upload the “new” ride did not get identified as a duplicate of the original Strava activity, I’m guessing because the canonical activity data (from Wahoo) was now slightly different.
Example: i20126021 and i58098934 are both matched to the same Strava activity which seems like it shouldn’t happen after a Strava export/import.
Hope this makes sense.
Hi. I just tried to bring in all my previous strava activities - and became a supporter!
I got an email saying the import was complete, but it only added 12 activities, while it “found” over 2000…
not sure what to do now… !
Strava import complete
Intervals.icu has finished importing your Strava history.
12 activities created
Strava import for athlete i304136 from Strava | Running, Cycling & Hiking App - Train, Track & Share…
Activity column headers are en
Found 2037 activities
Date format appears to be: MMM d, yyyy, h:mm:ss a Locale: en
  • Created manual i63227897 2015-07-28T05:40:00 Run Night Run, weight 72.5748 kg
Pick a couple of activities. Open the activity. Check the top right hand corner. It should say ~UPLOAD instead of ~STRAVA
This indicates that the activity has been replaced w the org file and not strava copy.
What I think happen.
2000 activities in Strava.
1988 activities in intervals.
These 1988 has been changed from STRAVA to UPLOAD
12 NEW activities were created. Somehow these are either new new or some other stuff. That you need to figure out.
At least one of your manual activities has elapsed time of zero. This was breaking the import. I have fixed this (these are skipped). Please give it another go. The ones already imported won’t be duplicated.
hmm… looks like I crashed and burned w/ my thinking. :smiley:
Thanks for trying to help! Much appreciated.
I tried this, but unfortunately it does not import all of my activities. 2.158 out of 3.192.
tagging @david
The importer wasn’t handling manual Strava activities (no activity file) properly and you have many of those. I have fixed this issue. They will now be replaced as part of the import. Any comments etc. are moved across. Tx for the report.
You need to re-run the import. It won’t duplicate activities already imported.
Thanks so much @david, now there is just 44 left. Should i work on the manually, or do you have e fix for those as well?
The ones with no time have been skipped for that reason. The hike on 10 Apr 2022 and the run on 30 Jan 2021 have corrupt fit files. You could try download a different file format from Strava and manually upload that.
The next swim is duplicated because the duration is not the same. You can probably just delete the Strava one.
I suspect that is probably the case for the others as well.
Thanks david, understood :slight_smile: Your help is very much appreciated. :pray:
I just did this… took awhile, but all 3382 activities have been replaced… and are now coming through the API.
What happens for future activities? New activities coming through the Strava API will not be available correct? What is the strategy going forward, should I disable the Strava connection in favor of Garmin or something else?
THanks
You should connect the source of the activities (e.g. Garmin) and keep Strava connected. Intervals.icu will delete the Strava activities but it will copy the segments across and link the Garmin one to Strava as well as Garmin.
Ok, I now have both Garmin and Strava connected, so I assume, I’ll be able to get them through the intervals API since Garmin is also a source for the activity, and the intervals code will prevent duplication :slight_smile:
Hi there
Imlost all my data from Strava on Intervals :cry:
I initially tried to try the functionality of “Import old Data” and limited the download to a month. This failed
So I limited it to a couple of weeks … that failed.
So I contacted Strava to get the link to my archive as requesting it from the link on Strava and it failed time after time. I eventually contacted Strava direct and a pleasant assistant helped me out and I received a link
I put the link data into the right place in settings on intervals.icu.
Still nothing updated after a week of waiting
I downloaded all the data myself as the link was only valid for 7 days ….a zip file that contained loads of folders etc
Any chance of a bit of help please to get my system updated ?
Many thanks
Pete
