Thanks. You’ve saved me a few minutes each day, in not having to recreate workouts again in TP.
Much appreciated.
Ok, it took a bunch of refreshes, eventually it showed up.
…and… OMG IT"S WORKING!!!
Won’t work on my ‘Work’ laptop. Could be a firewall thing (although I do have access to both Intervals and TP). Works on my home laptop though.
Hard to tell why.
If you wish, you can reproduce the issue and send me the logs, but I doubt I will be able to find the cause.
Where to find logs
No panic. It must be a firewall issue. I set it up on home desktop computer as well as home laptop with no issues. Same TP cookie. Thanks. Might send you the log anyway!!
I found a bug (or feature?) in 0.3.2/0.3.3.
Here is original steps on Intervals:
Here what I got on TP after sync:
And here what I expect (and what I still get using 0.1.1 version):
In recent versions step power is substitute with range instead of exact value. It’s unconvinient, plz fix.
Also, can you disable auto-update or at least let it ask me before program auto-update? Today it failed to run after closing, because I had symlink to tp2intervals-0.3.2.AppImage file in my launcher, and after it was seemlessly replaced with tp2intervals-0.3.3.AppImage, my link got broken. (Not a big deal for me though, I still can run it with java -jar tp2intervals.jar anyway. But may be for others…)
Thanks for your work on this project!
In 0.2.0 I switched from parsing raw step values to “resolved” step values as it easier and predictable. Here’s an explanation of this mechanism.
And yeah, I can remove this range.
Sure, I will figure something out with updates.
Just released 0.4.0 version
Added ability to skip already planned workouts. It checks type, name, load and special id(s) which I add to workout description on TP. If any of these parameters differs, a new workout will be planned. Old workout won’t be removed in any case.
Now the app can plan Run workouts. And can plan workouts with Pace and HR targets.
It should be fixed. Also you can change these ranges in Configuration, by default they are set to 0.
I disabled it, but you still will be automatically updated to 0.4.0. Now if new version will be released, a notification will appear.
Maybe later I’ll add update via ui, for now it’s a bit complicated.
Upgraded to v 0.4.0
I notice that actual absolute watts set in Intervals don’t transfer exactly to my Wahoo. It’s as if they get changed to a % of FTP and re-formed then (for want of a better phrase) to absolute watts then again when synced with wahoo.
It’s not a huge inconvenience, more of an irritation!!
I look at Wahoo expecting to see 270 watts and instead see 271 or expect to see 320 and instead see 319.
Makes no difference to the workouts at all but just wondering at the same time if its’s possible to sync the actual absolute watts set in the Intervals plan?
That how it works. From Intervals I receive exact watts for any target (%FTP, Zone, etc). But TP accepts only %FTP, so watts from Intervals must be converted into %FTP, by simple division. TP probably doing same thing as Intervals - it converts %FTP to raw watts.
Unfortunately, there be always an error in these calculations.
Can you send me your workout, your ftp and that planned workout in TP? I will try to reproduce the problem, maybe increased precision can at least reduce amount of miscalculations.
No stress. Thanks for the reply.
Literally only one watt out either way so there is no panic here at all.
Hi @Someone_Else - I have mailed you that log just a minute ago. It might be of some use to you. Thanks!
Logs are from v 3.0.2 I think
Looks like Wahoo has opened up a bit more, adding 4 new officially supported workout sources. Perhaps a chance for intervals.icu to get a foot in the door now?
Just click upload planned workouts in intervals.icu settings. Planned workouts are uploaded to my Bolt over Wahoo Cloud. Works perfect for me ![]()
Would have been nice to have Intervals.icu on that list. I haven’t done an announcement and tweet etc. yet because the API is still in beta.
Is there a way to see the logs? I am asking before I see the “Last uploaded 5s ago” but then I don’t see the workouts neither from roam nor from the wahoo elemnt application
I have making the logs in general more visible on my todo list. Must get that done soon.
I checked yours and at least 2 planned workouts have been uploaded.
Yeah, that’s exactly the problem, that I guess intervals push it to the wahoo servers, but for some reason I won’t see it in the device nor the application. If you tell me that it’s properly pushed then it must be something on the wahoo side
Anyway I wonder why sometimes it appears and sometimes not. I believe it has to do with when the workouts are added: When I have planned a whole week I can see the workouts for the next days, but when I try to add a workout for the very same day it won’t appear. I need to do some more tests but that’s seem to have something to do with it
Anyway thanks for answering and for the nice feature ![]()
