Hi
Is it possible to set ERG to off in Zwift and do the exercises in slope mode?
Many thanks
David
Hi
Many thanks
David
Using the Zwift Companion app you can turn ERG off.
Thanks Dave. I was wondering if there was a way to do this automatically within the workout builder.
You can create a step with the freeride flag. I am not certain but I think that will turn off ERG mode.
- 5m freeride 90%
correct me if Iām wrong, but then you have to deal with terrain changes in contrast to being able to choose your slopes like in slope-mode. My question: is there slope mode in Zwift or just erg on/ terrain on?
If your doing your workout in Zwift on the companion app your when you turn erg off it switches to incline mode you can then use the +/- to adjust it to your liking. Not sure if that helps you but thatās how i do my workouts I only use erg if I am doing a lower threshold workout. The terrain is not a factor when doing a workout in zwift itās not as hard going uphill from what I experience
When you do a workout without ERG all terrain is flat. You can change slopes with Companion app or + and - key on your computer. You can turn ERG on/off in Zwift workout menu. But also during ride with Companion app or press page up key and go to ERG ON/OFF Switch in screen.
I never use ERG because i believe that you have to learn the muscles pacing watts like outside. I only work with slope mode.
Will that do the same thing (turn off erg) on a Garmin Edge? Thanks!
I donāt think so. The Garmin API to upload workouts doesnāt support āfree rideā.
I donāt have a smart trainer, but a Google search has led me to find the following for Garmin workouts:
Open-ended is for Garmin
Free-ride is for Zwift
Is someone able to verify this, please.
Iām trying to assist a few mates that need the free-ride setting on their Garmins.
The Garmin API has this note for ātargetTypeā: The type of target for this Step. Valid values: SPEED, HEART_RATE, OPEN, CADENCE, POWER, GRADE, RESISTANCE, POWER_3S, POWER_10S, POWER_30S, POWER_LAP, SWIM_STROKE, SPEED_LAP, HEART_RATE_LAP, PACE
So OPEN is āfree rideā for Garmin devices? If so I will make that change. I canāt test it though as I donāt have a smart trainer.
Thanks David,
Iāll wait for feedback from friends or anyone here willing to test.
Open is considered āfree rideā but not in slope mode. Itās just ārideā.
alternatively, use āgradeā since OP wanted slope mode.
The other option is of course some other Trainer Controlling software. I think TrainerDay has a slope mode. BreakAway (iOS only) also has it.
targetType: SPEED, HEART_RATE, OPEN, CADENCE, POWER, GRADE, RESISTANCE, POWER_3S, POWER_10S, POWER_30S, POWER_LAP, SWIM_STROKE, SPEED_LAP, HEART_RATE_LAP, PACE?
So it could be used as a target not only POWER (3, 10, 30s), but also GRADE and RESISTANCE? Would you be able to add this to the workout editor? This would make training planning very flexible, especially when it comes to sprint intervals, which cannot be made sensibly on ERG, but in the grade / resistance mode it is possible. Besides, not only for this.
I would also test Open, but it can actually mean āfree rideā whatever it means in practice (you have to check).
Perhaps the use of Garmin API specific APIs may not be compatible with e.g. Zwift etc. (e.g. resistance?), But for planning your training by steering with Edge / Fenix it would be very useful.
Do you know if the Intervals.icu integration with TrainerDay can automatically trigger slope mode?
Hi, Iām not sure. Slope Mode seems to be a beta feature from what I read on their forum.
For BreakAway, itās there for quite some time already. (Future integration will add convert outdoor rides (FIT/TCX/GPX)
David, OPEN for Garmin devices is basically āride until next lap buttonā. So if itās included in an interval, then the interval will continue from 0 seconds until XXX seconds, waiting for you to hit the lap button. This is super useful for outdoor rides where I am riding a climb with longer intervals, or thereās a specific area of traffic that sometimes is faster than other times. TrainerDay has this āflagā on their workouts where if you send a workout to Garmin and it has āOEā then it will make the workout open-ended on Garminās calendar. I noticed that if a TrainerDay workout is sent to Intervals and then linked with Garmin Connect, the OPEN doesnāt work (I presume itās because itās not implemented here yet, or maybe the TD workout isnāt being sent with this flag since it isnāt Garmin ?).
There are lots of practical reasons why this is nice to have, apart from the traffic example. Say I have a few climbs in a row where the climb is about 20 minutes, but then I need to ride to the next one. Normally it takes 10mins other times it takes only 7, other times it takes 15. I could set the recovery to 15, but then it would make my workout length and TSS estimation longer. Sometimes I use this workout outdoors and other times indoors. Itās nicest to create 1 workout with the intervals of say 5mins, and then make it an āopenā interval. Now if I am on the trainer, itās 5 minutes, but if Iām outdoors using my Garmin, then it gives me as much time as I need to get to a good spot for the next interval. No needing to create multiple workout files and now there is adequate time to ride to the next hill/stop-light/etc
Tx for all the info. Intervals.icu does have an option to end the step when the lap button is pressed:
From your description it sounds like I should just make āfree rideā do OPEN for Garmin.
Iām working on integrating Intervals.icu workouts (using its Workout Builder) to automatically trigger between ERG Mode and SLOPE Mode (no user intervention).
Essentially a SLOPE based structured workout. (w/o ramps)
eg:
-1m 1%
-10m 2%
-1m 1%
or even a mix ERG & SLOPE Mode
-1m 50% ā ERG
-10m 2% ā SLOPE
-1m 50% ā ERG
essentially, anything <= 10% Power will be SLOPE mode w/ the % value being sent to the trainer.
No Slope Ramp support tho
Thatās a good idea
Although funny looking charts.
