Isn’t this what you’re looking for?
Ah so I have to add a time but it isn’t really used. Got it, thanks!
The time is used but you can end the step early with the lap button. Intervals.icu needs to have some idea of the time to calculate load and so on correctly.
Is possible to track for example exhaustion of W´and CP?
do you mean to create workouts using W’Prime? No. This is not available.
as for CP, also no, unless you change your FTP number to CP then it can be used interchangeably…
or do you mean the W’Prime line? (shown below as the black line)
When I enter workout plan based on distance and HR (for instance - 4km 78% HR), duration is calculated automatically. How is that “planned” duration is calculated? I would like that calculated duration to be closer to my real time at this HR level. What settings I might want to look at?
Here is what I’m talking about planning:
And, this is my real times:
Thank you!
Look at your pace setup in the Settings page.
I doubt that has anything to do with his pace settings, as he isn’t specifying pace in the workout.
I had the same problem with cycling. When I put in distance and power zones the duration was always assuming a 30 kph average, no matter what power zone I specified.
It is linked to pace zones. As soon as I type distance (4km), the duration is shown.
- Distance is specified (4Km).
- Pace uses duration and distance (min/Km).
- From the duration 30:16, I get 30.26667 in a decimal value.
- 30.26667 / 4 = 7.5667 min/Km.
My threshold pace is 6:15, or 6.25min/Km.
7.5667 / 6.25 = 1.21 (121%)
Joe Friel’s 7 zone setting shows 121% as the midpoint of Z2. I haven’t specified a zone yet, so not sure why it uses 121%.
Interesting. For cycling It just gives me 30kph no matter what power zone I specified.
- 30 km Z1 and - 30 km Z5 both give me 1h duration
there is no pace / speed settings for cycling…
Yes for cycling it just uses 30 km/h just so it doesn’t break. Better to specify cycling by time with wind, hills and so on.
Hi!
If I use HR as a workout base, how will the trainer (Elite Direto) act? I guess there will not be any ERG resistance as there is no input … it’s just a “free ride” with the HR feedback? Thanks!
You are right..
the workout will show a Middle of the zone1 - Zone 2 HR and it will just be a visual cue for you to follow.
Unless of course you use an app which is able to control your trainer using your HR under ERG mode.
Like this app of mine: (iOS only)
You have answered your own question.
If you keep your HR as close to a certain value, and adjust your power accordingly, you will get a good baseline test that you can repeat weekly/monthly to monitor progress. This applies the 50 minutes section only, for testing, and not the VO2 intervals at the end.
Hi, I am a newbie with new powermeter for outdoors. Many years with Trainerroad and estimated power of trainer.
And I would like to create my own workouts.
Does anyone could please explain how to create this workout?
Once I try it following your steps, I won’t have problems to create more.
I have tried it, but no bar coloured graphics shown below instructions of workout, so I think I am missing something….
This is the workout:
Warm Up:
- Ride for 5 minutes gradually raising your power from 87 to 119 watts.
Main Set:
Settle in for 80 minutes between 119 and 156 watts.
Cool Down:
- Spin easy for 5 minutes
119w is my 55% ftp, and 156w 72%.
Change the time format
For 5 minutes write 5m
See screenshot here for your session:
power: 10s
Warm Up
-5m ramp 30-55%
Main
2x
-16m 72%
-16m 55%
-16m 72%
Cool Down
-5m ramp 43-30%
See this post also : Depending on what head unit you use, you might need to change power smoothing to 1s (power: 1s)
Thanks!! Now it works. I Will try to load to my Karoo or Sigma Rox
Just loaded it to my Karoo and looks correctly with coloured bars.
And once I upload it to my Sigma Rox pairing iphone app, this is what appears on my Sigma pairing phone…
Hi, I’m new here and have been playing a bit with the workout builder. I didn’t find answers to the following questions, and have a few more thoughts:
Text that goes before the time/distance in a bullet appears as a note on my Garmin watch, text that goes after the power/HR/pace target doesn’t. Correct? Would it be possible to use either as a note? That would allow a note like “15m Sprint, 35m Recovery” because at the front that’s getting parsed as “15 minutes”. Otherwise, if the text at the end of a line is ignored, can it be marked with a warning? (aka “this is ignored, if you want to add a note move it to the beginning of the line”)
Is there a keyword to mark a step as Rest / Pause?
a) Is there a list of keywords like
maxeffort,ramp,freeride, etc? -
b) I’d be happy to read the text to workout conversion source code instead
In a block of repetitions (e.g. 10x effort, break) I’d like to skip the last break and instead add a longer break before the next block. Not possible yet, right? I’ve seen Garmin workouts do it - but the Garmin workout editor cannot create such workouts either.
Parsing 50m as 50 minutes is really unfortunate for swim workouts. Would it be possible to parse differently for swim workouts? Maybe with an opt-in at the top (aka “parse_m_as_meter”) so as not to break existing workouts? Then, if you want 50 minutes you have to write 50m0s or 50min.
When creating a swim workout, don’t simply default it to 25m but add a line
pool length: 25m. Makes it much more discoverable then. -
If I write “Press lap” can I also add a note to the workout step? Would it be possible to move “Press lap” into the keyword section between time/distance and power/HR target?
Is there actually a way to train with power when swimming? If not, could it be removed from the workout editor and make
Z2default toZ2 HR?
