A question, why i dont have the title of the activity in the calendar grid? But i have the text and description filled in
But for example in the same week
Can you send me a link to that athlete so I can have a look. Tx.
I don’t have in anyone, it’s just my training plan in Library called Duatlo with 222 workouts with 24 weeks. This was done when this feature was released, don’t know if it helps to debug
Thanks for all your hard work! Might have been covered already but haven’t found it - the ability to drag a workout to a different day on your training calendar? (Vs. Editing the date manually within the workout)
You should be able to drag and drop. It is currently working for me (Chrome on a Mac).
Look at that. I just had to press and hold a little longer on my iPad Pro and it works. Works great on my MacBook as well, just a user error haha thanks anyway
Aha. You had “Name” unticked in the “Colors” options for Ride. So thats why the weight training had name shown and not the other workouts. Anyway I have made “Name” always displayed for workouts now.
That was a tricky one !
Thanks for the debug
Hello!
Is it correct that if an athlete is set to HR/power/pace for workouts and i build a workout with
“10m Z1” the builder refers to power zones instead HR? Does the HR needs to be specified always?
@david: I love the text-input possibility for individual workouts. Now I want to “import” a 6months+ long training plan (i.e., a detailed ATP) from PowerPoint. 20+weeks, 5 trainings/week. Do I have a chance to input such a training plan without wasting my time with mouse-clicking and drag-and-dropping in a graphical GUI? “Real programmers do not use GUI and mouse-clicks”, you know
So, can I input multiple workouts into a plan just using a text editor in a single work-session? That would be a dream for me
default is Power
for HR:
-10m 50% HR
or
-10m Z1 HR
or
-10m 50% LTHR
can also use pace
You would need to use the API for that … it could be done quite easily if you know a scripting language.
Well, I used to use *nix shell scripting for living for a while, a few decades ago.
I suppose bash&curl should be good enough for this. Do I need an API key?
Disregard the question, I have found API access to Intervals.icu
If I build and apply a training plan, does it save the plan in the library tab so I can apply it again in the future or do I have to rebuild it each time I want to use the plan in the future?
I second that request about a periodization function. Yes, you can plan in the plan view and you can add notes in the calendar view. But that makes the planning process unnecessarily hard
But it would be really great if notes could be added directly in the plan view - so that blocks are clearly visible. Would be great as well if these notes in the plan also appears in the calendar view
No you can build it in your library and apply as many times as you like.
perfect, thanks David
I searched for it and didn’t realized that the Note is one of the activity types
Hello, @david
How can I create a workout and then get it to upload to my Wahoo Kickr or Tacx trainer so it follows it?
I see you can download different types of files but am not sure which one is the best or if it is even possible, thanks.
