Hi, I cannot get this to work.
I’ve saved a copy, given all auth as well connected to the API but no data is coming.
Thank you,
Thank you,
Open the file and go to Extensions > Macros > ImportintervalsICU and it will pull through the data from the API
Ahh I think its because the code/ formula is not copied across from the original Google Sheets file that @Aindriu produced - please copy it across from there into your file and it should work
Specifically you need to copy the formulae for columns A to E on the HRV-calc sheet.
I tried to set up a custom label with the date for each point as suggested earlier in the thread, but I haven’t (yet) figured out how to do this in Google spreadsheets.
Robert
only after he puts the sheet back
HRV Guided Training (Shared) - Planilhas Google
This version does not have the colored chart.
Also it does not have dates:
thank you
I know…
Copy the formulas from that version into a saved version of the one with the coloured chart… Its what others have done when they came across the same problem
Hello to all,
I’m trying google sheets but I can’t see the graph with the colours and data, I only see a blank sheet, I haven’t been able to find out how to do it, if someone can tell me how to do it.
@Olly_Thomas file has an issue. The formula’s on the HRV clac sheet are missing. If you have no clue on how this all works, have a a little patience until a corrected version is posted.
If you do know how to handle this, just copy the formula’s from @Aindriu 's file in the same columns on Olly’s sheet.
This is a work of multiple members each doing the part they have knowledge on.
Replying to this post,specifically to keep Alan Couzens, Python and the below podcast together.
Can you post the link to the colour chart version? Thanks
Sorry work is manic at the moment and I need to update to slightly - bear with me I will do it ASAP. Thanks!
hi,
Works using a computer, but how can I do this using an iOS device?
Tks,
Still waiting on that as well. Browser based or iPad for me.
Well,
the sheet is there fully working on desktop and 90% on mobile but we don’t have the knowledge on Google Sheets to automatically refresh the data…
Someone else will have to come up with a solution for that. Just like anybody else we have limited time available and need to respect/protect our own priorities.
I thought the best way to keep things moving forward was to post it as it is and count on another helpful soul to solve that remaining issue.
appreciate your efforts.
tks,
Aagggghh
I was messing around with this this morning trying to get a copy I made of v1.5 to pull in custom wellness fields. I ended up having to delete the v1.5 file and now upon redownloading I cannot get it to work at all. Any help would be appreciated
I keep getting an access denied error.
Continually get the message below
I’ve deleted, redownloaded, closed, opened, done everything I can think of to get it working again but I can’t
In the data source settings dialog - Global Permissions - click on Edit permissions and re-enter Basic - user - Api_key
