I have a few questions about the Fitness Graph;
What’s the best one to set the fitness graph to, “absolute value of shape” or “percentage of fitness”? Of course you can switch with both, but which one gives you instant feedback and which one gives you the best feedback?
Should I be concerned that my “form” says -221% …after more than 6 months of little to to no activity? Is there a shortcut to getting in to positive numbers? (rather than switching from percentage of fitness to absolute value)
For a fanatic amateur who has serious ambitions in Gran Fondo’s, what’s the best data to set to the graph? Which ones am I forgetting and give me the best indication that I’m doing well?
Some workouts have drastic affect on progressing, and some of those workouts are easy (read: fun) to be performed. Does the same workout have a different affect in a later state of my fitness? What I actually want to say, when I see the green line drop into the High Risk zone I often plan a day or two of rest to get back into the Optimal zone. But can I use former workouts to prevent the green line from dropping into the High Risk zone? If yes, how? Which data indicator should I compare or use to chose a perfect affective workout? (read: I want to steer the green line as much as I can)
Hope I can count on your serious responses, I am desperate for some good advice. Thanks!
