Hi I currently have blank Watt prime number. is there some kind of test you recommend me to do. to get a estimate or how does it work?
Look on your /Power page - you should have a W’ number next to your eFTP. You can then copy this value into the /Settings page
Thank you , how did I ever miss that :S
You should also see this thread:
edit: that estimated W` is not very useful if you haven’t fed the model w/the necessary max efforts. In my case, I’m coming back from an extended break and have not done max efforts. I can easily find myself w/a W`bal depletion exceeding my W` w/out having gone deep.
