Had to reinstall it a couple of times, because I also had the wrong values issue (FIT 64, etc…) and no authentification prompt.
But now everything works great.
As I said it before, a great upgrade for your Garmin, when you are using ICU way more than Garmin’s Load numbers.
The style of the widget is also so clean and informative as I love it to be.
Further feedback:
Only thing I noticed, apparently you used a Sunday start week, and I use a Monday start week on ICU and my life.
So weekly load and ramp rate is off today (Sunday) as the widget already started a new week and I’m in my old week. At least thats my explanation.
That’s no biggie for me, but perhaps you might consider givin an option for that or pulling the start of the week from icu or …
Actually I use a Monday start week, however when I pull the weekly values I do that directly from the athlete page that must default to a Sunday start. I will see if there’s a way to make that configurable.
My eFTP is always wrong. I have an eFTP for running and for cycling which are both 241W but the glance always shows 200W.
I don’t know which eFTP will be shown (I prefer running because that is what I do most of the time) but maybe it could be possible to make it a setting in the menu so you can choose which eFTP will be shown. As for now it shows for both the wrong value.
BTW: the glance looks great, so I hope the values will be correct soon
I’m working on a setting to show either run or ride eFTP (or both). I’m not sure why your eFTP is showing incorrectly right now. DM me your API key and I’ll check it out.
Hmm OK thanks. Could be that the dataset is still to large for your watches versus my tests. I’ll reduce it down to 1 week in the future rather than 2 weeks and see if that helps.
Ok think I’ve got to the bottom of this one finally.
On devices with very low memory, it is not possible to pull the activity information from the future as it exceeds memory limitations. If the device has low memory, it will now only pull 3 days of future activities. With higher memory, it will pull 7 days.
Please let me know if this finally resolves it. @FrankGNL the glance view should display nicer too.
Version: 0.08b (may take a couple of hours to appear)
