All working fine now - thank you!
@david had multiple reports from users with ios devices that they are unable to click OK on the permissions authorisation screen.
Can you please show me what is displayed, what should be displayed (the details of the next planned workout), and your device details please?
Forerunner 920XT Pleasee!
Thanks, I will DM you to test further if thatâs OK. I think it may be a language issue - I am guessing that âworkoutâ is called something else for the activity type?
In the same boat here.
Will it work on the Forerunner 230? Thats what my wife has. She is on IOS for me to test this. I only have an Edge 130+.
Do you know if all users cannot auth on iOS or only some users?
Itâs the case with any of my friends that have tried it. Has anyone successfully authorised with ios?
@david I canât even temporarily publish it for the 230 unfortunately as it it doesnât support the sdk version.
I made a short video of my experience: Intervals glance widget - YouTube
Yes. Exactly the same on my iPhone.
I did not succeed authorising on iOS. In the popup neither ok or cancel buttons work. Only logout.
Thanks. Unfortunately I donât have any control over the display of that page, so either it is a Garmin issue or an intervals.icu issue. Hopefully David can help.
Indeed, could be either. Is there a way to display this authorisation page outside of garmin iOS app? On the desktop or directly in safari for iOS?
But it is really only that first time authorization page making problems on iPhone.
As a âworkaroundâ I used my Samsung Pad/tablet to connect GC with my watch and complete that authorization process - and killed that connection directly after that.
Since then the widget gets all data from my iPhone without issues.
Easy installation, looks like a great widget. However on my Fenix 6 Pro I donât get data, just NULLsâŚ
Hi Michel, thanks, looks like a good case for a debug. Iâll DM you.
Without a fix for the oAuth issue on iOS, could there be a way to use the connectIQ settings page to input an oauth token generated outside of the app? I donât have an android device I can use to work around the issue
Thanks for your work on this.
No support for Venu SQ?
Thanks.
The Venu SQ does not support Glance widgets unfortunately.
