Great widget, love it. However, on my 245 music, I cannot scroll down to the next planned workout. What am I doing wrong?
High demand for Power (avg. Watt) on FR245 ! Real looking foward!
@James_Eastwood_Socks
No hope for garmin Venu SQ ? Tnx
Will be FR 935 supported please? Thank uou
If it is not already supported, but not a new device, then it is too old and doesnât support Glance style widgets.
hello. Garmin Marq Adventure (Marq 1st gen) supports glance widgets but not supported by your widget. Could you add this watch? Using Glances on a Compatible Garmin Watch | Garmin Customer Support
This widget looks amazing.
Does this reply also indicate no Instinct 2 possibility?
Load and Ramp is not correct for me anymore, dont match with intervals.icu. Fitness, fatigue, form are still matching.
Could you please make it available for the Garmin Tactix AMOLED ?
this is a new watch and supports glances
Great widget! I just canât get the form to match the websiteâs. Fitness (27) Fatigue (35) always match but Form (-28 widget -8 website) is always wrong. I have checked both fitness page and overview/profile page. Any ideas?
Would this explain the difference?
I donât calculate the form, I take it directly from the API as that dayâs values, so maybe a question for David.
I was being an idiot. The website had form as absolute - the widget displays as %. Changing the websiteâs form setting to % brings them both into alignment! Thank you.
Itâs also possible to choose which you would prefer in the widgetâs settings in the Connect IQ store
Hi @James_Eastwood_Socks, I would love to try this but have a Venu 3 which the widget is not currently compatible with. Seems like it should just work if youâre able to add it to the list of compatible devices. Thanks!
@James_Eastwood_Socks, I was thinking of implementing this myself but no sense in duplicating work. Iâd happily buy you coffee to get access to this. Any chance of updating the list of compatible devices to include Venu 3? As an aside, this hard-coding of a list of devices (which I assume is required by Garmin) seems so fragile and just extra work for developers.
Yeah itâs a pain, because itâs also not a given that it âjust worksâ. Every new device as a minimum needs to be run through the emulator just to be sure, but often also requires some code tweaks.
Iâll update for newer devices as soon as possible, but Iâm currently in Mallorca getting in some big bike mileage. Keep on at me and Iâll do it asap.
Amazing, thank you! Working great on my Forerunner 955.
I have a forerunner 955 too so if it doesnât work well there, we have problems ![]()
