Please also for my new Forerunner 965
Hi. Is there a way to help you to get the widget also available for the Venu (1st gen)?
Is the forerunner 45 able to be added? Thanks
On my Forerunner 955 it doesnāt seem to work, only shows N/A?
Could you add support for the MK2i?
All, if your watch supports glances properly, then this app can (or does) work for it.
I am hoping to get some time to re-factor a lot of the code, including adding support for newer devices, soon. Iāve just got a lot going on with training, racing and work right now, but it is somewhere on my to-do list!
If youāve got an older device that isnāt yet supported, youāre out of luck.
is“t compatible with the Episx 2 Pro ?
My last planned workout was about in March, widget always shows this workout when i donāt have a planned.
Iāve got it on the list to display " no planned workout" where that is the case.
James - im well behind the times running a Fenix 5 - itās not coming up as compatible - is the watch too old to support this widget - it looks amazing!
Looking forward to see how it is on the 255 as Iām thinking of making that my next purchase and moving away from the Fenix devices.
It works fine. The photo is taken of my FR255 3 comments backward.
when do you made it compatible with Epix Gen2 Pro ?
Works well on 255. I use a 955 myself.
Yes too old Iām afraid!
New version 1.2
Changelog:
Updated to latest SDK
Support added for the following devices:
Epix Pro Gen2 (all sizes)
Fenix 7 Pro (all configs)
Forerunner 265(S)
Forerunner 965
Fixed:
Last workout would still show if there are no newer workouts planned
Available in the connect IQ store.
Hi. Could you add support for Marq model, please? Hardware and software similar to Fenix 6/Forunner 955 family which supported. Thank you
Regarding the null value, Iāve reinstalled the widget authorizing āupdateā (not sure if this was necessary) and it worked.
Can you explain me why changing the Training Load Priority and āUPDATE ACTIVIESā on ICU Settings will change the FIT, FAT, FORM values?
