Custom activity charts
This was a fantastic skeleton, thanks
added to the intervals chart as background zones
will add to the 30 min block chart (but colour the bars) shortly
If someone has time and skills, I would love to get the kilometers spent per Gratient custom cart (e.g. 10km above 8% grade, 5km above 10% grade etc.)
I’m looking for something similar
In my case, I want to put the VAM in perspective of zones, for example, how long the athlete stays in each ascent measure divided by 100 units.
Some types of charts only make sense for certain types of activities (e.g. run activities, activities with power, activities with at least one interval, activities with certain custom streams etc.).
Perhaps there should be a way to signal “don’t draw this chart for this activity”. Either simply not setting a value for chart or setting a value containing a reason - or error message.
(posted in the wrong thread first, so now I have to put some more text so they’re not similar)
Thats a good idea. If the script does not return a value or returns null then the chart is hidden completely when displayed on an activity. Unfortunately you can’t use “return” in these scripts without defining a function and invoking it:
function chart() {
  if (true) return // not the right type of activity or whatever
  // your chart code
  return { data: [], layout: { title: { "Hello" } } }
chart()
If you are editing the chart script then you will see “Script did not return a value object” instead of just blank.
I’ve been using labeled blocks to get around that, and around excessive nesting - see break in labeled blocks.
I think the function approach is a bit less exotic but this seems to work too. I’m not sure how you’ve implemented the sandbox so not sure if there’s any advantages to any approach.
I didn’t know about those, thanks:
out: {
  if (true) break out; // not the right type of activity or whatever
  // your chart code
  let chart = { data: [] }
  chart
This also creates unexpected behaviour as Plotly disregards Text values in the x-array when numbers are present. If some work intervals do not have a label, only those will be plotted and the intervals with a text label will not be shown.
I haven’t found a way yet to tell Plotly that it needs to interpret the whole x-array as text values, so I came up with this intermediate solution:
x.push("°" + (iv.label ? c + "-" + iv.label : c))
The ° sign as first character, makes sure that all values in the x-array are considered as text values.
You can remove that and just include this in the layout options:
layout = {
  xaxis:{"type": "category"}
Thanks for that tip!
Works like a charm.
Anyone able to assist, please, with the syntax required to create a chart with the x-axis in hours (activity duration) and then the y-axis using any of the metrics, eg. kJ?
I can work out what the various sections of the code means, but I’m not sure of the correct syntax used, so I created a Google Sheets document to allow a line-by-line explanation of the coding. I’m sure this will help other people besides myself.
TIA
so the quoted code is running through each of the intervals in the activity and picking out the label and average watts for the work intervals and saving them in their own array. (it then moves on to the plotting bits)
the options for what metrics you can pick are here
it sounds like you don’t want to look at the metrics aggregated into their intervals though and instead want the time series, in which case have a look at the activity stream models
best bet is probably to explore some charts already shared that look a bit like what you want and adapt them
Thanks for the reply. My request is two fold:
  • gain an understanding of the coding
  • chart certain metrics per hour to compare for each hour.
The custom stream has kJ/hour, but looks to be total kJ/duration, which is an average. It doesn’t say if the first hour was more or less than the second, third, and so on. I can view the summary by highlighting each hour, but would be easier to view across all activities and athletes.
Sorry I can’t explain this better right now but this might serve as a skeleton.
intervalLengthMin = 30  // change this number for different interval sizes
// define variables
//activity = icu.activity
streams = icu.streams
// filter time and watts for points with positive velocity
intervalLength = intervalLengthMin * 60
time = streams.get("time").data
watts = streams.get("watts").data
heartrate = streams.get("heartrate").data
velocity_smooth = streams.get("velocity_smooth").data
// body of work
Int_number = []
Int_power = []
Int_work = []
Int_hr = []
Int_length = []
Int_text = []
Int_colour= []
for (let i = 0, IntV = 0; i < time.length; IntV++) {
	z1 = i
	for (j=0, temp_power = 0, temp_hr = 0; j < intervalLength; j++, i++) {
	 if (i === watts.length) { break; }
	  temp_power += watts[i]
		temp_hr += heartrate[i]
	if (IntV % 2 == 0) {
	  Int_colour.push('rgb(242, 212, 146,1)')
	} else {
	  Int_colour.push('rgb(242, 149, 89,1)')
	z2 = i
	temp_text = `Mins: ${z1/60} - ${Math.floor(z2/60)} `
	Int_number.push(((z1+z2)/2)/60)
	Int_power.push(Math.round(temp_power/j))
	Int_work.push(Math.round(temp_power/1000))
	Int_hr.push(Math.round(temp_hr/j))
	Int_length.push((j-12)/60)
	Int_text.push(temp_text)
data = [
    x: Int_number,
    y: Int_work,
		text: Int_work.map(a => `Average: ${a}kj`),
		width: Int_length,
		marker:{color: Int_colour},
		hoverinfo: 'text',
    textposition: 'auto',
    type: 'bar'
		x: Int_number,
		y: Int_hr,
		text: Int_hr.map(a => `Average: ${a}bpm`),
		width: Int_length,
		marker:{color: 'rgb(171,35,40, 0)'},
		hoverinfo: 'text',
		yaxis: 'y2',
		type: 'line'
  type: 'bar',
  y: [200],
	orientation: 'h',
layout = {
  title: {
    text: `Work done for each ${intervalLengthMin}min Interval`
	showlegend: false,
  xaxis: {
		ticktext: Int_text,
		tickvals: Int_number
	yaxis: {title: 'Power (w)'},
	yaxis2: {
		title: 'Heartrate (bpm)',
		showgrid: false,
		overlaying: 'y',
		side: 'right'
	paper_bgcolor: 'rgba(245,246,249,0.8)',
	plot_bgcolor: 'rgba(245,246,249,1)',
  margin: {
		l: 35,
    r: 40,
    t: 40,
    b: 20
chart = {data, layout}
chart
I think this is kind of what you were asking
Many thanks @Ben - this was like getting a short push to close the gap in the bunch. It gets me closer to having a working example. I’ll play around and see what else I can “report on”.Also easy enough to change to 60-mins (second image).
no worries, it was an edited version of a chart that I shared to the public library months and months ago (hence why I forgot to rename the x axis).
If you look at another one I shared (All Intervals (Power Avg + Norm) or HR selection) you can add dropdowns within the charts to flick between whatever you want to report on, once you get to grips with first getting the data you want there’s a shed load of flexibility with displaying it.
Is there already any way to access data for an entire period like last 90 days or season? Or for now the only available data available is from a given activity?
I need to add support for custom longitudinal charts for that. However you can get at the athletes current MMP power curves and so on from a custom activity chart. See ActivityJsData.
Example pulling the athletes MMP power curve for the last 42 days (from activity date) and extracting best 5m power:
let mmp42d = icu.bestPower['42d']
let best5mWatts = mmp42d.getWatts(5 * 60)
Hi David! Yeah, I have saw this type of long term data on some examples and while I was plaining with icu object but nothing for elevation, which for my use case is crucial and that’s why the question. It’s also a question how far is the implementation of the feature request for the elevation goal and how easy/hard is to add this new elevation data to icu object for modeling other use case.
Hi! I managed to reproduce this plot from Core to better identify heat zones based on skin temperature and core temperature :
Original : https://corebodytemp.com/pages/cores-heat-strain-index
Activity chart (public see ’ Skin vs Core temp and Heat Zones’) :
