Accuracy of power meters
I’m aware of the assioma hack as I was the one that came up with it. Still not a great solution for real mountain biking though as the pods are a bit exposed on the ends of the cranks. Fine for gravel I guess, although I tend to use road pedals if I know I’m not going to be walking.
Mike
BTW, is there a way to discriminate between actual coasting (0 W data points) and loss of connection between the PM and the recording device? It seems my Rotor INspider loses the connection rather frequently for a few seconds up to half a minute. For Strava, these events are recorded as 0 W/coasting and hence the avg power is reduced. In the attached screenshot, the cursor is positioned in one of these 30 s windows with no connection to the pm. I know about the data correction tool on intervals.icu. But how do I know if I actually stopped pedaling or the connection was just lost? (In this case, it was easy, since the route was flat. And I can hardly go 38 kph for 30s without pedaling.) pm_connection_loss
Is there no difference between null and 0 on the graph? Null being ‘no data’ and 0 meaning 0 Watts :sunglasses:
In the fit file, there is a “0”. Interestingly, the first 3 seconds when connection was lost, there are still non-zero cadence values in the file (99 rpm). This seems to be a pattern. I found another 20 s gap in the same file. Speed an HR are actually increasing, while the power and cadence values are 0. Also note the non-integer HR values. :slight_smile:
EDIT:
They should indeed change the standard for recording data. If the connection to a a sensor drops, there should be a -1 or a string instead of a zero. This would simplify data processing/curation.
Please post a link to that activity on Intervals.icu and I can have a look. I have seen data from Strava with “null” for missing data points rather than zero. Intervals.icu does distinguish in its “fix data” function (“missing data points” are the nulls).
Interesting. Maybe different devices record it differently. I’m using a Fenix 3. … Anyway, here is the link: https://intervals.icu/activities/3949754876
It’s zeros unfortunately. My PowerTap hub and Edge 500 occasionally drop data points and these show up as nulls and not zero. So as you suggest its probably PM and head unit dependent.
Thanks, David. I will probably replace the PM. I have virtually no dropouts with the INpower on my road bike. It’s only the INspider causing trouble. Maybe I switch to power2max. It would be compatible with the Aldhu cranks.
Hi David. Recorded my last ride with a fenix 5. Interestingly, this watch seems to record blanks for dropouts according to the tcx file (while the f3 recorded 0 Watts in this case). However, when I inspect the fit file with GoldenCheetah, there are 0s in the power field. Not sure which format is exchanged between Garmin Connect, Strava and Intervals.icu, but when I use the fix data tool here to replace blanks, it doesn’t seem to change anything.
You could use the replace zeros option. Intervals.icu doesn’t get the raw files from Strava, only the individual traces.
Since this post started discussing the fluctuations in the signal for powermeters, I have noticed sometimes the signal on strava for high endurance rides if the guy is super strong looks like smoothed out or something, any guesses on what it is?
That depends and ‘super strong’ may have less to do with it than being able to pedal consistently.
Was it indoors or outdoors? Indoors, you can set your trainer to a fixed Watts output, by using a phone app via BLE and ride a virtual course using the Ant+ channel on a desktop app.
I routinely do that.
Outdoors, if you have long, flat straights, like I do in my area, you can achieve a similar curve - or lack thereof - by turning the pedals consistently. I have lots of examples of that as well.
Outdoors, I forgot to mention - so maybe some guys can just cruise at 270-280 watts with minimal fluctuation since they have smooth pedal stroke?
I thought it would be some special filter though!
Yes, some can: Like a trainer ride (not that wattage though :sunglasses:)
Having said that, I don’t see the point, but I think there are tools to ‘flatten’ your power curve for a ride, by eliminating outliers either way…
I see, yes this guy is a monster, he beats our asses so badly in the Tueasday Chaingang. He many times does 2-3 hr rides at that power with that kind of flat line but where we live the terrain is rolling, therefore I thought he was applying some filter.
But now I know is possible… is it a less wasteful way of pedaling ir a worth-acquiring skill?
I think so, yes. The smoother and more consistent you can keep your pedal stroke, the better. The RPM doesn’t really matter, but for most that will be ‘somewhere’ between 70 and 90 RPM. Higher (sustained) power levels will be easier to maintain at higher RPM, but on rolling terrain, that is less obvious.
At any rate, it’s worth practicing your pacing skills, high and low RPM.
This seems to be a fitting topic, I have Garmin Rally Pedals and have compared them to three other power meters so that I know they are the benchmark. My turbo trainer Tacx Neo 2 is displaying 7% higher power output, is ther already a way to adjust this difference? I could not find it with the bikes or the individual rides.
You can fix your power with Actions > Fix Data
There you can apply a scale factor of e.g. 0.93 to fix your power data
