Hi Jason,
Here’s my £0.02’s worth [ from over the pond ] some things you mentioned resonate with me from training over longer distances like yourself. Over the years I’ve discovered/learned the following.
- We are impatient animals and sometimes don’t appreciate the adaptation phase of the workload we’re doing but cannot adapt to immediately. [ i.e. we write cheques that our bodies cant cash ]
i.e. You know that you can ride x/miles or n/hours [ in your head ], but we don’t realise that it takes time for our bodies to ‘catch up’ and adapt properly to the workload (duration and intensity). As we get older, that becomes more of a challenge.
My favoured plan is to work on 3 weeks on, 1 off, and increase distance by 10% each month to properly get used to the distance. I appreciate your event is next month and you’re kinda seeing-how-it-goes but well done so far!!
You might benefit from doing staggered distances between now and july, i.e. split your endurance rides into 3 shorter ones, i.e. 2hrs, 4hrs, 6hrs. (instead of mashing one big distance out every weekend/sat/sun) as this will still build your fitness but more progressively, less is more over a week. If you can do something every day to get your legs used to continuous riding without it being hard, then you’ll see benefits.
Swap one day out for a mixed weights session - like kettle bells/squats…
- Correct fuelling is often overlooked/under estimated , underfuelling at breakfast, digestion/absorbtion and on the bike nutrition.
Breakfast: Oats, blueberries, a scoop of protein powder/25gms/ eggs if you can.
~ 400-600kcals before a long ride, wait 3-4 hrs before riding so you’ve digested it properly (if poss)
Work out your Metabolic Basal rate. Eat those kcals every day with complex carbs and protien so you get a good recovery. 1.4-2 gms protein per kg of body wieght for recovery. Endurance /distance is hard on the legs/body.
Work out how many kcals/carbs per hour you’re hitting an hour , I think @John_Koch said something along these lines.
My rule of thumb, anything below 80% max HR (for me) is ~60gm carbs (230kcals +/- ) per hour - (Styrkr do a Mix 60 powder in sachets that hits this ). If you’re having to negoticate hills on a route repeatedly, take a 30gm gel and it won’t hurt to grab something to eat every 20-30minutes, even if it’s a pack of haribos or confectionary bar/SIS/rice cake ( make some flapjack bars with mixed nuts and berries/dried- and pack a few up and hit one every hour. Always carry slightly more than you think you need , just in case you have a bad patch.
From what i have found, some gels just don’t work for me (SIS ones mostly), The Styrkr products are very good. Im not sure if you can get these where you are.
Caffiene in the last hour or two will help as it reduces your perceived exertion level so as you get fatigued it helps with concentration - a caffine gel works
Once you go past 2-3 hrs - if you’re mid zone 2 HR/Power, you’re predominantly relying on fat burning + carbs as fuel. The calorific defecit is acellereated over time as you can’t maintain a set workload effort over time the further you get to 80% mhr+ . Over 80% or near threshold power you’re burning carbs mostly.
- Recover well.
Always finish with a recovery drink, You can buy maltodextrin and whey/soya/vegan protien powder from amazon, cheaply, 20gm of carb, 20-25gm protein, in a shaker, 400-500ml of water < 30mins after your finish your ride gets recovery going. OR use a pre-mixed version if u prefer.
Carb rich meal after your’e done and rested… stagger the protein over the following day. Your recovery starts from the moment you finish the ride to when you ride the following /next day after. Keep tabs on your macros.
- Regular bed times.
Track your sleep and learn what works, when you feel fresh and when you dont.
Plan your nutrition and rest - refrain from consuming alcohol [as much as you can ]
- Get a foam roller and use to ease your muscles - even better get a massage gun/physio if you can afford that.
- ice baths are great for this
- You’re only human. Do what you can. If you’re fatigued so much from Sunday/long ride - rest /have an easier low volume/intensity day.
Psychologically, you’re already there as you’ve been able to smash most that distance. Good luck and hope you find this useful
Dan
