WHOOP integration added
Agreed it’s working fine for me now.
Thanks for the information - yes, it works! Just connected.
Cheers,
Michael
Hey folks. I just noticed from the past 2 weeks I’m not getting any wellness data from the WHOOP. I already paired it again but it doesn’t seem to solve the problem
They have started reviewing my rate limit increase request (after 3 weeks!) so hopefully this will be fixed this week.
WHOOP have increased Intervals.icu’s rate limits. There shouldn’t be any more problems.
Thank you!!!
Awesome - for the first time, my WHOOP data has been loaded in the morning! Hurray!
Thank you, David!
Yes! Awesome news!
@david: would you ind to add “sleep efficiency” to the data? In my opinion it’s more interesting than “sleep score”? To my understanding the score just says how long you were in bed - which is completely independent of “how well you slept”!?
Cheers, Michael
Since yesterday, WHOOP has stopped syncing again
Which athlete ID? There aren’t any errors in the logs and lots of people are getting WHOOP data.
me ( Andrea Bonvicin )
immagine no sync
Aha. I had a look in the logs and you need to disconnect and re-connect WHOOP.
WHOOP have updated their API. My own WHOOP is broken so I need to look at someone’s WHOOP data to update. Any takers?
Works for me, just tell me what you need.
How do I opt in?
Thanks for the offer but I updated the API some time ago with help from @ilbonvi .
Does that mean that Whoop data can no longer be ported?
No WHOOP imports should work fine. Are you having issues?
I have gotten a WHOOP a month ago and just enabled the integration. I want to keep the HRV though from my Garmin though and I unchecked it from Whoop, but it keeps overwriting my values (it does work for resting HR but not HRV) Any idea how to prevent that? It would be amazing if there would be a priority setting for each field in case you have different devices. Thanks!
Hello, I’m trying to sync some swimmers on ICU with their Whoops 5.0. They have indeed connected their Whoop and accepted my invitation to follow them, but I don’t see any of their data and they themselves don’t see their data in ‘Fitness’. Anyone has any idea what the problem might be? Thank you!
