Wellness prompt, how does it work?
Hi all,
In the settings you can choose to be prompted to enter wellness data (suppose that would be a daily prompt). However i never got a prompt. Entering wellness data works without a problem.
Is it still under development or is it a bug/wrong setting?
Cheers :biking_man:t2:‍♂
That is still under development. Sorry for the confusion. It is supposed to ask you once a day to capture wellness.
I also have just synced wellness data from Garmin, hope this will not mess up with RHR in the settings and so on ? Thanks
Hmm if you have ticked the “Resting HR” box for Garmin Connect then it will overwrite whatever resting HR you have in settings.
Hum, I checked the box but nothing has changed in my settings.
New data should come in from Garmin several times a day. I need to look into that.
Hello
I have revoked Garmin access and linked again and it fixed the thing. But I affirm that despite checking in the wellness data box I didn’t get any update before the revoke-relink action
To load old wellness data you need to click the “Download old data” button and choose the date range you need. It might take a while.
I add the problem despite doing this. It’s the revoke relink action which fixed the thing
Hi @david , realise this is old but did this ever get fleshed out?
No not yet.
@david just wondering, should the wellness prompt now work so you get each day reminded?
AFAICT, there is no prompt. You can click on any calendar date/day and then enter it manually at any time.
There is but I never used it and don’t know if it works as itended.
ooo.. I see it now. I have it as “prompt” but have never seen any pop up or such AFAICT..
Is there a similar shortcut as described in the calendar for the fitness view so I can trigger the wellness prompt?
Prompting for wellness data hasn’t been implemented (yet?).
@david could you add the wellness data entry to the dropdown too, see C)? it’s missing in the fitness view when you click on A), then B).
Hi there,
would it be possible to set up a daily e-Mail reminder to fill in wellnessdata with a direct link to the current day and the wellness pop up?
I´m constantly forgetting to fill out data my garmin does not track like soreness, fatigue etc.
There is a prompt option on the Settings page.
