Virtual rides from Zwift -> Garmin
Hey all,
I noticed that my yesterdays virtual ride on zwift (which was sent to Garmin) does not sync to intervals.icu calendar.
I have both the garmin connection + zwift connection enabled.
I also noticed this post from years ago:
But since I enabled the zwift connector I would dare to assume that zwift would send the data over to intervals ? or is that assumption not correct?
thanks for any clarification,
Matijs
and I just read this info on the zwift connector page:
You can’t download historical activities from Zwift (yet?) and you need to make sure your FTP on Zwift matches your FTP on Intervals.icu. I am hoping Zwift will extend their API to support settings sync.
so that may explain it :slight_smile:
You got it all correct.
Garmin will not forward activities not recorded on their hardware. And Zwift will only push new ones at the time of ending them, not historical ones.
