My training normally consists of warming up- stretch - run - cooling down.
During stretching I pause my Garmin.
In Garmin Connect this is removed from my training.
In Intervals.icu the time paused is added to the run. Is there a way to change this. My stats are off by this.
Which stats are being impacted? Intervals.icu mostly displays moving time which shouldnāt include paused time. Short pauses are shown in the activity trace charts, long pauses (coffee stops) are removed.
Hereās one of mine. The moving time is 36:55 but the graphed time is the elapsed time, 55 minutes , and thereās a long pause where Iām waiting for something. The watched auto paused, hence the difference in moving and elapsed time.
Then thereās a bunch of pauses where Iām shopping.
Same here. It shows the total time instead of the time i actually ride.
Will pauses like this impact ride eFTP calculations?
i (personally) find that the pause times flat graph provides a better overview of the run/ride I did vs the one that is shown in Garmin Connect.
With Garmin Connect, I have no idea the amount of time spent at ācoffee stopsā or rather, time spent at CheckPoints during eg: a Trail Race / Transition time during an ironman type event.
AFAIK, it does not. Itās removed from it.
Well, Iāve turned auto-pause off on my watch so the intervals.icu graphs will look prettier.
for pretty ones, I just use the ones from Strava / Garmin Connect
Agree with OP, itād be nice if there were an option to remove pauses entirely from the graphs etc.
I second that, also would like to have an option for that. Another side effect of the pause being considered is that it increases the lack of sync between the planned workout and the actual workout.
I would like not to have the pauses waiting for a traffic light interfere with the period I am in or out of an interval.
They (hopefully, i.e., rightly) do;-)
And WĀ“, and HRR, ā¦
Think this says enough to show my opinionā¦
I think most coaches would say itās against the idea of a workout to hide the time spent recovering.
I wouldnāt say itās āhidingā, and itās probably different (culturally?) for running vs cycling, but short pauses due to things like crossing a street is very normal and doesnāt impact a workout or long runās fitness value at all
I have added a āShow pausesā slider to the āOptionsā popup:
Pauses longer than this setting are not displayed on the chart. This is stored per sport.
It is a nice feature, but the calculations for the laps still include the pause.
Nothing to do about that?
Unfortunately that is much more difficult to do. All the calculations and so on assume you are doing hill repeats or similar (like in cycling) which generally wonāt have pauses (if there are it counts because it is rest)/ Its not really geared to intervals that are just random 1km chunks of your run.
Why is the minimum of the pause needs to be 30s? Could it be changed so that I can hide even smaller pauses?
It is now 10s and the slider works in 10s steps.
