Using laps as intervals
The “Reset” option under the ride timeline has been renamed “Analyse” and displays a dialog with some options to control how intervals are detected:
The “Keep all laps” option prevents any filtering of intervals from laps based on power or heart rate. This is useful for analysing ramp tests.
The interval list page now supports editing of intervals for precise edits. You can only edit “Work” intervals and deleting an interval replaces it with “Recovery”.
I also fixed an “out by one” error with intervals from laps. The last data point (usually second) of each lap was being left out.
something is wrong here - I cannot get it to work properly. It gets the laps at different times?
https://intervals.icu/activities/3341522131
Do you have the “privacy circle” enabled on Strava? There is an outstanding Strava API bug that sometimes messes up laps for activities using the privacy circle.
Definitely have that enabled. But the laps on strava activity work fine? https://www.strava.com/activities/3341522131
As in my SIGMA ROX 11 plan your training, it does not automatically insert laps when changing the training phase :frowning:
The bug only impacts the API :frowning: Maybe try making it a private activity?
good idea, sadly didn’t fix it.
What I need to do for these cases is support direct upload of .fit files to replace the bad API data from Strava. Thats on the todo list.
So, I can already upload a TCX file?
:slight_smile: No such luck! …
I thought so, but since you specifically / only mentioned FIT files :joy: If I would need to manually upload something, it’s not uncommon that it is a TCX file instead.
Is there a difference between selecting Use Laps at bottom or selecting from Analyse drop down? It seems like I cannot get my choice to stay selected, I leave the activity and come back, and auto detect has reoccurred.
When did that last happen? There was a bug that would sometimes cause activities to be re-analysed losing manual edits and so on. But supposedly that is fixed.
“Use Laps” is the same as ticking the box on “Analyse”. In future Analyse will have more options.
would be good to be able to compare power meters if you’re going to allow unload of fit files (e.g. different fit files for the same ride) for 1m, 5m, 20m etc and as a line graph
May 10th. I was trying to compare 3’ efforts and I couldn’t get May 10 efforts to show. I think the laps did stay eventually, but not until I selected Use Laps (not analyse) and I couldn’t get that days efforts to show in graph when I had May 2020 selected, they showed up when I selected “Today” from top?
Hmm. The interval search page is a bit buggy. It was one of the first things I did and hasn’t had much attention since.
Makes perfect sense, considering the site is called as it is :joy:
My laps are detected when the file is from my Garmin, but not when it is frm Trainer Road. Though, the laps do show in the TR files in Strava.
Please msg me a link to one of the rides where the laps are showing up in Strava but not in Intervals.icu. Tx.
