Training guidance tools using the API
For some strange reason, I’m not even getting this popup to input API and password →
I’m following the steps you laid out before:
  • Open a fresh copy of the sheet (don’t try to open the shared one! - download your own copy first) → Done, I’ve downloaded the file (1.6) from the Google Drive to a local copy, without even opening it online.
  • Dismiss the two errors → Done. I do also get another error about “Privacy levels”. I’ve read elsewhere on the forum to click “Ignore Privacy Levels check”, which I did
  • Enter your AthleteID in the highlighted cell and quit the cell to make sure the ID is saved → Done, even intermittently saved the file.
  • Then goto Data menu and hit refresh → Done
  • The Web Access dialog should now display → It does not, unfortunately. It does however display the “Microsoft.Mashup…” error again.
Running Microsoft Office 365.
Thanks in advance for any help :slight_smile:
Is your data coming from Strava or from the original device, eg. Garmin, Wahoo, etc.
Intervals is not allowed to retrieve data from the Strava API.
I’m not at my laptop, so can only check in about 2 hours.
I’m also running Office 365 and it all works.
The error message may indicate that the resource is forbidden from where you’re trying to access it??
Try this:
Data/Get Data/ Data Source Settings / Global Permissions / Clear all permissions. Then click on Refresh
Is anyone else having problems in Activity_icu v3.01, where the Zones are not being updated? @William_Barnes
Good spot @R_S1, I’ve just put an updated version (v3.02) here
that should address that issue.
