my workouts from wahoo systm are no longer syncing with intervals.icu.
i disconnected then reconnected the link to wahoo without any change.
the only way that my workouts show up is if i use “download old data” on the settings page.
anyone else has the problem or can help me to fix it?
I’ve noticed this over the weekend. Workouts from SYSTM are not syncing but activities from Elemnt devices are. I started the Wahoooligan Tour and none of the workouts have passed through but a brick run straight after stage 2 did (recorded on Elemnt Rival). Yoga has not synced this morning.
Seperate but also an issue on an iPad (and maybe other tablets). I emailed the .fit/.tcx file to myself so I could manually upload. It’s impossible to upload using a mobile device. The upload command cannot upload the file if its stored on the iPad or in a folder on iCloud Drive. It’s greyed out. Minor inconvenience as I’ve had to boot up a Mac to be able to do it and the import got the load incorrect. Would be great if the upload command can work on an iPad.
That greyed out thing is largely due to the fact, that iOS (or usually Safari on iOS) adds a .txt extension to unknown file extensions (but hides that of course )
So the file is actually no longer called something.fit but something.fit.txt and since the uploader does not support .txt file extensions it’s greyed out.
There are workarounds though. You’d need an app that allows you to rename files and shows the full filename. I personally use Blink (a SSH client) which comes with rudimentary linux/unix commands including mv which allows me to rename files on the command line when I move them to the right folder.
Did you find a solution ? I have the exact same problem for the past 2 weeks. Workouts stopped automatically syncing from Wahoo Systm to Intervals.icu. Every time I have to “download all data” to get it to sync manually.
No unfortunately Garmin doesn’t pass those on to Intervals.icu.
I had a look in the logs and I can see some activities from the 14th and 15th of March come through but when Intervals.icu tries to download the file it gets a 403 (access denied) error.
I can see on the 19th you did get an activity from Wahoo. So maybe this is something they have sorted out already?
Unfortunately not.
Activity on March 19th was outdoor ride with Wahoo Bolt. This syncs perfectly.
Wahoo SYSTM is still bugging. Workout is to download the original file from Garmin Connect and manually upload to intervals.ICU…
Hi, thanks for looking into this. You can check my profile, I did some new SYSTM workouts which didn’t upload and didn’t use the workaround yet to get them inside intervals.icu so that you can do some debugging if you want.
Also thanks for the clipping tip. Didn’t notice it and even if I had I wouldn’t have guessed I could fix it by simply clicking the message.
