I recently switched from TP to intervals.icu and i’m still trying to wrap my head around how to create swim workouts especially including rests.
I’ve read through some old threads but could really find a working way.
If someone has a working example workout and is willing to share i would be very grateful!
So my swim workouts are structured like this:
pool length: 50m
- Warm up 200mtr 70-80% Pace
- 20s
3x
- Drill 1 Catch up 3 lengths 50mtr 70-80% Pace
- 20s
3x
- Drill 2 Kick only drill 3 lengths 50mtr 70-80% Pace
- 20s
3x
- Drill 3 Zipp up drill 50mtr 70-80% Pace
- 20s
3x
- Easy, Moderate & Hard paced free style 50mtr 70-95% Pace
- 20s
10x
- Moderate - hard 100mtr 80-95% Pace
- 20s
- Cool Down 200mtr 70-80% Pace
It sort of works on my garmin but the “- 20s” are not recognized as a rest timer but a swim or kick set timer. I haven’t tested it in the pool but i would imagine that unless you stand completely still the watch will still track and add meters.
Another question i have is that most of the intervals show up as kick set (“Beinschlag”) on my garmin. In other words they all count as drills. Is there a way to set it to swimming freestyle or front crawl? I noticed that when i use:
Brust 400 meters 90% Pace
It actually is recognized as Breaststroke by Garmin
Kraul 200 meters 80% Pace
on the other hand is again recognized as a kick set
Hi MarKra 1994!
Are you directly uploading this workout from intervals to GarminConnect? I have a Fenix 6 pro and it didn’t work, the uploaded workout doesn’t match what’s in intervals at all.
In the sense that the uploaded workout doesn’t look and work as if it was written using GarminConnect.
That’s why I enter all my swimming workouts directly into Garmin.
Thank you for your time and help! I tried your method but the result is the same.
It rudimentally works. But it marks everything as a drill so i think Garmin won’t record any stroke data. I imagine if you would just swim without drills and structured workouts in mind this would be just fine. Maybe they will add further additions here. In the meantime i will continue using other apps for the swimming portions.
Have you tried structuring it like my last follow up? Other than that i’m either using “swim coach app” to create my workouts which then sends it to my garmin or i’m using my garmin on the fly.
