[Solved] Having elevation/climbing misread data on runs
On most of my runs, the climbing is way too high. This is a sample run that says 2542ft of climbing when garmin has it at 164ft. It fixes when I manually turn off the elevation correction setting in the activity, but this is weird since garmin’s activity that is imported to intervals has the correct elevation.
Is there a way to turn off the elevation correction as default for all my activities or a solution to this bug? Thank you!
Not a bug, user error…
On the activity page , open Actions-Settings and disable Elevation correction. Set your device as having ‘Correct Elevation’
Then reprocess the original file (also from the Actions menu) and the climbing field will be exactly the same as the one on Garmin.
