Run metric similar to efficiency
I’ve only been here a month or so but really like this whole thing. It reminds me of the OG desktop version of SportsTracks.
But anyways. I’ve come to enjoy using efficiency (power/hr) for a sensitive marker of fitness and how a ride went overall in the context of fatigue, temperature, if I’m sick, etc, .
Is there a similar one for pace when running. I’ve looked but didn’t see anything. Something like gap/z2hr.
Thanks!!
If you don’t have a running power meter there won’t be anything built in. But there are some fields created by users that would do exactly what you want. Some use GAP some use AvgPace
I made a set of custom fields (Cadence, Power, GAP, Efficiency, Fitness and Technique).
Make sure to read the remarks in the script and the linked forum thread to get what you’re after.
Awesome. Thanks for sharing. Looks like what I was hunting for
@MedTechCD Looks exiting. How do you use it in your own practical application using intervals.icu?
Thinking maybe we’ll Trimp involved. Less ordinal than zones, more continuous.
The metrics Efficiency, Fitness and Technique are based on the book ‘Running with power’ by Jim Vance.
A better cardiovascular system increases Fitness (more power per heartbeat). A better running technique increases the distance covered per watt (bouncing your center of gravity up and down eats a lot of power that is not contributing to horizontal movement). The product of both is Efficiency in meter/heartbeat, speed at equal internal effort, that’s what your after.
Cadence increase is for most beginning runners the best way to improve technique. Power increase is the result of improving cardiovascular fitness. Breaking it down like this gives you the opportunity to focus on one or the other for a period. Focus on higher cadence for a couple of runs makes your body adapt quite fast and while at first, you may find it difficult and performance (speed) is not improving or maybe even reducing, the higher cadence will quickly result in speed gains a the same HR.
Running more frequently and/or longer, will increase cardiovascular performance.
You can plot all Custom Field metrics on the fitness page to follow up on your performance.
You can modify these Custom fields to follow up on other Heartrate zones if you want. Just make sure to always set GAP, Power and HR ranges that represent steady state zones.
I am probably setting it up wrong. I added the fields to the run activities. Tried reprocessing a couple of runs, but nothing on the charts:
Do you have the results in the summary for the reprocessed activities?
No. It is probably because of the hardcoded values which I did not change. I have to look into that.
The easiest way to setup the different values is probably this:
  • Go for a steady state Z2 run at your chosen HR (I cap my hr for Z2 at 122bpm)
  • On analysis, set your target HR and range (example Target=119; Range=5 will take into account 114-124bpm)
  • Set Target Power and GAP to an estimate and set the range wide open (example Power Range=100 and GAP Range=180)
Now run the script and see what it returns for Z2RunPwr and Z2RunGAP. Use those averages as targets in the script and rerun the script.
Filtering outliers for GAP and Power gives you a more precise result because you discard:
  • HR anomalies
  • GAP errors due to bad GPS
  • Sudden accelerations where HR is lagging
  • etc.
It also isolates the Z2 part of a workout where you mixed in some efforts at higher intensity.
@MedTechCD
I tried setting the following values and tried reprocessing this run: Intervals.icu
hr_target = 140
hr_range = 10
gap_target = 350 // GAP in sec/km
gap_range = 180 // GAP range in sec/km
pwr_target = 380
pwr_range = 100
Rerunning the script gave me values.
You think the values makes sense for this run that was supposed to be around a Z2 run, maybe a bit in the low end, as it was a wrong run.
Could you please share your exact setup for the charts. I am struggling a bit to get the right and left axis to show proper values:
@MedTechCD Also I am curious on why nothing is returned on this run. This is an easy run in Z2 for 30m ending with some strides.
Is it because the script is designed for clear Z2-runs without any speedwork in the end at all?
Edit — Do - it is probably because, there is no power data on this one…
Looks exactly what is expected.
These values are all very slowly changing metrics. To see the changes on the graphs, you need to ‘zoom’ quite a lot.
I can’t just give you my exact setup because the numbers are quite different per athlete.
Best is to set only a minimum value for the axes and let the maximum auto adjust. You may have to switch the order of the metrics to get Fit and Tech on the left axis with a min of 0.48 while Eff then goes to the right axis with a min of 1.3 for example.
The second chart needs cadence and power on the same axis while GAP get’s the other axis with a minimum defined in m/sec.
It needs some fiddling to get a comprehensive view. You could also just plot only 2 metrics per chart, each with their own axis minimum, that should be easier to setup.
Here’s what I got:
and
The script needs HR, Speed/Pace and Power.
Is it on purpose you name both graphs 3 wk avg, but in the second actually use a moving avg with 7d?
Now, I reprocessed all my runs from this year and altered the axis a bit:
I noticed that I also get values on my threshold runs:
Is that caused by too wide zones (I left power and pace pretty open), or should I just ignore those in the graph (using a tag or something similar), or should they be included…
How do you get all those garmin metrics to show up below the name of the activity?
edit: got my answer
