To get the labels, you need to:
- Right click on the dot, add Data Label
- Right click on the data label, Format Data Labels
- Tick the boxes and see which information you want to view, and what not.
@Howie : use the simple version, IThlete_chart_v1.5-LocalFileOnly and if the reference to your downloaded file isnāt working, paste the three columns in the wellness sheet.
It only has a sheet for wellness and the three needed columns date, hrv, restingHR.
Nothing is column number referenced. The iThlete sheet uses the column headers as named ranges.
Is that a Windows version file? Iām on macOS.
The simple file @MedTechCD refers to works on Mac, it doesnāt have any links to external documents. You copy and paste the data from a manual download and it should work.
Super. I added āValue from cellsā and set the range as ='iThlete HRV'!$B:$B. This creates labels for each dot, but it gets a bit confusing. Is it possible to have the pop-up box as the date label and not the series and point info?
The data values being used are not date values, but the X;Y values in columns D&E.
You can show the date in a label, but it will be permanently showing, which results in a cluttered look. Select the date in the āValue from Cellsā option.
That is why I have resized the data points to match my understanding of the chart.
Also, the graph is not always correct. Iāve done HIIT when it showed in the Orange and/or Red followed by two days of L2 (Coggan levels) riding. By day 4 I was back in green, and benefitted from the 3 day block.
Office has no standard way of changing the text on hovering over a chart element. The only way to change that text, is to use āvbaā.
I may do that eventually, but right now, Iām somewhat saturated by all the new programming stuff. Office, Power Query, API, cURL, batch files⦠Iāve done so much stuff that is new to me during the last month, that I need a bit of rest to my mind
And to be clear, Iām super grateful that you have taken the time to learn all that stuff and made this spreadsheet possible. The label thing is clearly a very, very low priority thought. If anything, eliminating errors and increasing user friendliness are clearly more significant.
100% Itās just info to be used with all other info to help inform decision making.
So Iāve been playing around with the Google Sheets version over the weekend - this works better for me as you can refresh data via the web version which I donāt think it possible with the Excel Power Query version. There doesnāt seem to be a way to colour the zones, so I have had to stick to colouring and changing the shape of the points.
I have made other tweaks for my own use, but can share if it helps.
Welcome to the āDev teamā⦠your assistance will be appreciated
thanks
Here is a copy of the Spreadsheet I modified. Athlete ID and API Key need to be entered into cells the HRV_calc sheet (personally then hide this sheet). I removed the refresh/update button as I had set the script to run whenever the sheet is opened. You can manually refresh the data by going Extensions/Macros/importIntervalsICU.
Planned to use this mainly on mobile, therefore the chart to its own tab and formatted a summary info āpageā giving today and yesterdays results.
Not taking any credit for this, as Iāve simply modified the Excel and GS provided by others to meet my own needs.
Good job!
Looks like a really nice start. Sync worked right away.
Hopefully someone is able to improve the graph.
I would love to get access !
Thanks, credit is where credit is due.
Isnāt that the objective of āopen sourceā stuff? To let collaborators help to improve it.
The Google sheet link above is active for everyone. Just save your own copy of it and work your magic
Make sure to share your work!
Super cool. So easy. Thanks!
Two edits I made for readabilty:
Change the date format on āHRV_calcā:
=IF(ISBLANK(Wellness!$B4),NA(),CONCATENATE(MONTH(Wellness!$B4),"/",DAY(Wellness!$B4)))
Add custom labels to Data series 6, 10, 11 & 13 on āHRV Guideā in order to see the dates:
HRV_calc!AA4:AA60
This is giving me a āview onlyā option on mobile. Wonāt let me edit to input athlete id or API?
Save your own copy!
As MedTechCD has said, save a copy. If everyone uses the same file you wonāt get meaningful info as it will change.
