I am trying to import a number of FIT file running workouts into the workout library which I have previously exported from Training Peaks.
The warm up (step 1) as well as the interval section (step 2 incl. 10 on/off repeats) seem to come across correctly, but cool down (step 3) is missing completely.
I have checked the FIT file using fitfileviewer.com and step 3 seems to be included in the file.
Also, the original workout includes some text in the description field in TP which does not come across either, but I am not sure if this is even included in the FIT file. fitfileviewer does not show anything.
I tried exporting the workout as as ZWO file from Training Peaks as a test. This one does includes the description text. It also includes the cool down step, but it got rid of the âpress lapâ commands from the original workout.
This did not result in a usable workout though. Looks to me like Intervals would be expecting power targets, not pace targets for a ZWO workout.
It means you have to press lap in order to advance to the next lap.
However, the specified duration is technically just a comment, because it does not do anything. It only gives a guideline but leaves the flexibility to handle the exact duration according to circumstances (e.g. prolong the final step until you reach home).
As mentioned above, the last workout step was left out completely by the import. In the first workout step, the âPress lapâ option was added correctly, but strangely the duration indication was changed from 20 min to 10 min by the import.
I have tried the importer with a number of workouts which are designed similarly in the last days (all exported from Training Peaks as FIT files). They all produce the same issues on import unfortunately.
When playing these same workouts on a Garmin watch (pushed from Training Peaks to Garmin Connect via the API) they work flawlessly, therefore I believe the FIT files are fine but the importer does not read them correctly.
No, the problem was not solved. I ended up importing and then adjusting/correcting the workouts manually.
But it sounds strange that .fit file upload does not seem to work at all for you. To me it appeared that the import did not reproduce everything correctly but worked in general/with some exceptions.
I am also having issues with fit files. They look good in the viewer, but when uploaded into intervals.icu the workout is just wrong. The swim for instance is in minutes, all in z1, but the workout is supposed to be intervals at a distance.
Sorry for the belated response but could you please email one of the files with the cooldown step missing to david@intervals.icu and I will have a look.
Regrettably, I can confirm the claims made by others as I am also encountering comparable problems with the 80/20 endurance .fit files. Appreciation for investigating this matter, @david !
Tx for sending me the original file. Unfortunately Intervals.icu canât import that. It doesnât have pace targets. The zones are just included as text in the note fields. Currently Intervals.icu canât generate swim workouts with target_type=swim_stroke/open as in the file.
Thanks. I have added support for that. Intervals.icu doesnât support steps without duration or distance so that open ended cooldown is given a duration of 10 minutes. I will deploy the change Friday am.
Iâm having a similar problem with Zwift zwo files importing. I have previously done them but the latest ones of the same file are missing the warm up part and they are also adding a distance to the workout.
Iâve added a picture with both files showing the correct one (green) and the latest one imported (red).
Could you please email me (david@intervals.icu) the zwo file for that workout. I recently added support for run zwo files. That shouldnât have made any different to a ride file but I need to check.
Thanks for the files. I have fixed this for deploy Tues AM (GMT+2). I wasnât expecting to see pace=â0â in a bike workout, thought that would only appear for runs. That is now ignored for bike workouts.
