New Garmin Fenix- data not appearing on Intervals.icu
Hi all. Fairly new user, still coming to terms with Intervals.icu.
I have just recently moved to a Garmin Fenix (from Apple Watch) and since wearing it my Trainerroad workouts are not appearing as I would like on Intervals, ie there is no interval data present.
It also appears as though activities are being duplicated, although I am NOT recording the activity as an indoor ride on the Fenix.
I have my Strava account linked to intervals, and haven’t changed any settings since getting the Fenix.
Any advice greatly appreciated.
this data still looks like it’s coming from healthFit (from apple watch?) and not from TrainerRoad.
Also, AFAIK, you can’t connect the Garmin to your TR workout. (it won’t send speed / dist etc data to your watch as they are not connected). you say that you’re not recording the activity on the Fenix, so that means youre not using it for anything at all? It’s entirely out of the equation?
Hi, thanks the reply.
Good point re HealthFit- I’ve disabled it.
Correct, I’m using Fenix for health monitoring and all non-cycling activities only. Bike workouts are recorded with Garmin Edge (outdoor) and TR app (indoor). I also have a Strava account, which is linked to both TR and Garmin Connect.
Is this a fairly standard setup, or could/should I be doing something different?
Cheers
this post shows what I’m doing specifically for my setup.
in short…
TR App → Strava → intervals (caveats apply - see linked post - basically coz of Strava Rate Limits)
Egde → Garmin Connect → Intervals
Egde → Strava → Intervals
Intervals would do Duplicate Filtering…
you would need to see what’s the source of the 3 diff workouts. (you only showed screenshot of 1 - which was coming from healthfit)
You can get TR activities via Strava or Dropbox. Strava activities duplicated from other sources (e.g. Garmin Connect) are deleted but name changes and some other settings are kept. Other duplicates e.g. same ride via HealthFit and Garmin Connect will duplicate unless the file is exactly the same. Garmin Connect doesn’t pass files from non-Garmin devices on to Intervals.icu.
https://support.trainerroad.com/hc/en-us/articles/204889060-Dropbox
Thanks guys, appreciate the responses.
I’ve disabled HealtFit- I think that might have been the cause of the duplication.
I’m not sure why the TR activities didn’t propagate to Intervals from Strava as I haven’t changed any settings since getting the Fenix… I’ve manually uploaded them and will see how things progress over the next few rides.
Thanks again :+1:
