I’m a new user of both MyWhoosh and Intervals.icu. I started using the integration about 3 days ago and all activities are affected. Issue
Activities are imported automatically from MyWhoosh into Intervals.icu. Heart rate and cadence data are transferred correctly. However, power data is missing from every activity. The power graph is not displayed at all, and power-related metrics cannot be calculated.
What I checked
I verified that power data is recorded correctly in MyWhoosh and is visible in the activity details there. The same activities also show power data correctly in Strava. The issue affects all activities since I started using the MyWhoosh integration three days ago. MyWhoosh exports the activities as GPX files, and I confirmed that the exported GPX files contain power data within the extensions section. Intervals.icu successfully imports heart rate and cadence from these files, but the power stream appears to be missing, which makes me suspect there may be an issue with how the power data stored in the MyWhoosh GPX extensions is being parsed.
As an additional test, I imported the same GPX file into GoldenCheetah and then exported it as a FIT file. After manually uploading the FIT file to Intervals.icu, the power data was imported correctly and the power graph was displayed.
Has anyone experienced the same issue recently, or is this a known limitation of the current MyWhoosh integration?
But that would not explain the difference in gpx vs fit.
Check it anyway, Intervals will not analyse power if threshold isn’t set.
PS: the chance that Intervals is using the GPX files from MyWhoosh is almost non-existing. GPX files have very little info in them. Intervals’ direct connection gets the data in a much more structured and detailed way over the API.
PS2: on the Data tab, you can download a version of the data that Intervals received.
Do you have any idea how to fix it? If I convertfrom gpx to fit file and upload it, I can check it in intervals.icu like this. You can see that there is power tab.
Do you have MyWhoosh installed for a longer time? If so, try to reinstall it. That’s the only other issue I can find here on the forum. Plenty of people use MyWhoosh without issues.
PS: did you configure the FTP and power settings after my post, or was it already configured before you imported the activity? The power settings used are those valid on the date of the activity! If you want to update the settings for that date, click on the button
I just installed MyWhoosh and am seeing the same thing with my first ride. All of the power data is missing from the direct upload. Power is also not there on Garmin Connect after downloading the .gpx (no option for a .fit) of the ride and importing into Garmin.
Power is there on Strava with a direct upload. So I downloaded both the original file (a gpx) and Strava’s own gpx (They have two options, “Export GPX” and “Export Original”). When I upload the original downloaded from Strava, I again have no power. When I upload Strava’s “Export GPX” version, I have power data and it is what I expected. The gpx which got me power on Intervals still has no power on Garmin Connect - I suspect Garmin just ignores it since their gpx export also does not include power.
The MyWhoosh gpx and the Strava “Export Original” gpx are both 494kb. The Strava “Export GPX” is 605kb. I think most of that size difference is just in extra characters for formatting. One potentially important difference which I noticed is that the MyWhoosh original and Strava “Export Original” have the power value as a float/decimal - 100.0, 102.0, etc. While the Strava “Export GPX” which worked with Intervals has the power value as an integer - 100, 102, etc.
