@Krzysztof Many thanks for adding Tymewear & Dfaa1 analysis to MyTrainPal. I will post an analysis of a couple of runs based on Tyemwear thresholds from a recent Ramp Test with the analysis from MyTrainPal in case anybody is interested in what the platform can now do with the extra metrics. It was very useful advice & much quicker than I managed doing it all manually.
Prompt
Can you compare the run that I did today with the ramp Test done on 8/3/26 & a similar 10K run done on 29/3/26 please. I am looking to see if you feel that the likely Tymewear estimated AeT (HR Endurance Zone <110bpm & HR VT1<123bpm) from the Ramp test corroborates with the decoupling of 4.1% for today’s run, (but 0% for the longer 10K run on 29/3), with the Tymewear & DFAa1 & RR/a1 data from today’s run. It felt very close to AeT in terms of RPE today & perhaps a little over it by the end of the run, moderate rather than easy probably. I could have easily carried on but was starting to fatigue a little, though the fatigue was probably more neuromuscular (legs) rather than central. Tymewear has my AeT for power at 138W which seems too low based on RPE & an equivalent HR for 138W of power. But it would somewhat back up the slight neuromuscular fatigue after a relatively short easy run. Though the longer 10K run had no decoupling & so it might just be extra fatigue for today’s run. Also running at 138W my running gait would likely be negatively impacted (it would fall between a fast walk & a jog, so likely unnatural) & my HR way below my HR AeT/VT1 of 123bpm & so I feel that I would be gaining little aerobic benefit really. I do know that runners always tend to overestimate how fast an easy run should be but 138W would just be too slow for me to maintain comfortably in terms of gait & engagement I think.
Answer - Thought for 31s
To analyze your progress and validate those AeT estimates, I’ve compared your Run Ramp Test (Tymewear) on March 8, the 10K run on March 29, and your Long aerobic run from today (April 4).
Comparison Overview
1. AeT Validation: HR vs. Power
The Tymewear estimate of 138W for AeT does seem significantly conservative based on your recent performance.
- March 29 (10K): You held 167W at 113 bpm for 71 minutes with essentially zero decoupling (0.05%). This is the hallmark of a “true” aerobic steady state. If 138W were your limit, we would have seen significant HR drift at 167W over that duration.
- Today (April 4): You averaged 160W at 107 bpm. Even with the 4.1% decoupling, your efficiency factor (Power/HR) was actually higher than the 10K run (1.49 vs 1.47), meaning you were technically more aerobically efficient today despite the drift.
2. DFA a1 & RR/a1 Analysis (Today’s Run)
Looking at the raw autonomic data from today’s session, we see a clear transition:
- 0–20 mins: DFA a1 stayed well above 0.75 (averaging ~1.1–1.3), indicating very low stress.
- ~30 mins mark: DFA a1 crossed below the 0.75 threshold for the first time as your HR hit 110 bpm.
- 30–60 mins: It hovered between 0.69 and 0.85, while HR stabilized around 111–114 bpm.
This strongly suggests that your metabolic VT1 (AeT) is likely right around 110–115 bpm, which aligns perfectly with the lower end of the Tymewear HR endurance zone (<110 bpm) and is well below the 123 bpm VT1 estimate.
3. The “Decoupling Mystery”: Intensity or Fatigue?
The fact that you had 0% decoupling at a higher power/HR on March 29, but 4.1% today at a lower intensity, confirms your RPE assessment: this was likely neuromuscular or “accumulated” fatigue rather than an aerobic breach.
When you are “freshly” fatigued (neuromuscularly), your gait efficiency drops. Your heart has to work slightly harder to maintain the same power output because your muscles are less “springy” (lower vertical stiffness), leading to that 4.1% drift even at a low heart rate.
Coaching Takeaway
- Power Target: Ignore the 138W AeT estimate for now. Your gait and engagement concerns are valid—running at 138W would likely be mechanically detrimental. Your “real-world” aerobic floor for training is closer to 160–165W.
- HR Ceiling: Your cap for “easy” runs should stay strictly under 123 bpm (VT1), but for pure aerobic recovery, staying near that 110–112 bpm mark (where DFA a1 was ~0.75 today) is the sweet spot.
- Fatigue Check: The decoupling today was a “fatigue signal.” Since the 10K was rock solid, your aerobic base is fine; you just need a bit more recovery to bring that neuromuscular snap back.
This is the Compare Activites Chart from Intervals & then the Tymewear analysis Tab for the Ramp test for perspective as to my usual manual method of comparison. It took me significantly longer than 31s & so a good addition to MyTrainpal. Again many thanks..
