@Gerald thank you for the info. I have seen that the new 1.83 Zwift version is out! I will wait for my update and see if the problem was solved. These past days I could workaround the issue by force exiting the Apple TV app.
Hi everyone. I noticed that my Zwift rides yesterday did not sync to Intervals. Is the issue above causing this, which will hopefully be resolved with this update?
For the interim, I manually uploaded the .fit files which was easy enough.
My zwift ride didn’t show in Intervals yesterday, but it seems to have fixed itself this morning. Seemed like a temporary thing on Zwift’s side if I had to guess.
I had one other report of missed activities from that time. I looked into it and Intervals.icu didn’t receive a webhook from Zwift. Seems to be working now so hopefully this doesn’t happen often.
Those pesky webhooks. Thanks for looking into it!
has any update been made? Recently it no longer rounds the watts up or down. Before it rounded up from 188 to 190. Now it stays at 188 watts in Zwift
I noticed this yesterday afternoon after a Zwift update came through on AppleTV.
Yeah it’s a Zwift thing. On their forum some people have it, others don’t. At least ramps are smoother now.
Zwift asked a while ago if Intervals.icu would like unrounded workouts and I said yes. So they must have released that.
Hi David,
I’ve run into a small synchronization issue. My coach had planned workouts for this week, which loaded into Zwift with no issues. Now he changed them and they don’t update in Zwift, even after disconnecting and reconnecting intervals.icu. So for now I have to manually export to Zwift, which is not a problem at all for me but I just wanted to let you know of this small bug!
Thanks for this great product ![]()
This was supposedly fixed (by zwift) per the above posts. You on the latest version? Not sure if Zwift forces you to update.
Yes. Zwift are working on how they encode it in the fit file and soon it will show up on Intervals.icu.
When the Zwift + TrainerRoad integration launched earlier this week, Zwift added an RPE survey at the end of workouts (although not sure if it’s just for TR workouts or all workouts)
Does intervals.icu get this data too when the Zwift activity syncs? If so, could it be used to populate the RPE field?
Unless this was added in the latest update, I haven’t seen any RPE survey for workouts I did the week prior to this week. The workouts are from the Intervals.icu integration.
It would be excellent if my Intervals.icu library of workouts would always be available on Zwift, and not just the week’s workouts. Mainly I have a Z2 block that I have to drag onto the calendar each time I wish to ride it (I’m not structured enough for a schedule :))
The problem there is that some people have huge libraries of workouts. All the Intervals.icu workout upload integrations upload “the next 7 days or so” which is a way to solve the clutter problem.
I’ve been having issues where my Zwift activities are syncing but they are automatically deleted. I have to enable the show deleted option to see the activity. When I click on the activity to undelete it - nothing happens. It doesn’t work…
Any way to make the workout upload automatically with the "show_avg=“1” " allready? like it was when downloading it directly in intervals.icu
Unfortunately the Zwift API doesn’t allow that attribute.
