Intervals.icu and Zwift Integration is live!
Hi. Just started using workouts synced to Zwift. Easy to build workout too - thanks.
Workout uploaded to Zwift ok, completed, but it has not syncing back to Intervals. I’ve checked the upload download boxes are checked. Anything else I can check.
i’m using strava to aggregate both zwift and outdoor rides (outdoor with a wahoo bolt v2 computer). what is the recommended setup so that i don’t get duplicate activities?
Hi, my sync from Zwift is not working at all. Beginning of the Year it worked but now ? Everything is activated and intervals.icu is listed in my Zwift settings. The recorded workout is sync from Suunto to intervals but not the recording from Zwift. Any ideas ?
Best regards … Jens
There was something wrong with your Zwift tokens. I see you have re-connected so future activities should come through. Unfortunately the Zwift API doesn’t support downloading old stuff.
hi David, i experienced the same thing last week. but it looks like it is fixed. thanks :=)
Now everything is working. Thanks for your Support !
I’ve noticed that the data from my recent week of cycling on Zwift cannot be automatically imported into ICU. I haven’t used Zwift for virtual cycling for a long time. It was working normally around March, and I haven’t modified their connection settings. How can I resolve this issue? Thank you
Did you try to reconnect? Might be that you need to re-authenticate given the inactive period.
Attention: Zwift sync does not support history sync. Anything missed will need to be imported manually.
You will need to test with a new ride to see if it comes in or not.
I see your ride on Monday came from Zwift. Is this resolved?
Yes, the problem was resolved after I tried to reconnect the ICU and Zwift. Thank you very much for your help。
Hi @david
Trying to figure out what I’m doing wrong. I recently connected Zwift so that I could have the workouts auto-upload to Zwift. I have one workout scheduled for today and one each day for the next three days, but for whatever reason, only the workout scheduled two days from now is showing up in the workouts “intervals.icu” folder. Today’s workout and the other two never showed up. Tried disconnecting the Zwift link and reconnecting with no success. Any tips?
Any update here? As we enter zwift racing season, it would be great for them to improve weight synching.
Some info on running workouts:
@david , seems there is an issue with the Zwift integration, tried to set up RUN workout today and I get the following error: Zwift upload failed: java.lang.NullPointerException: Cannot assign field “thresholdOverride” because “zw” is null. I have my threshold setup in Zwift as indicated above. tried with both time and distance based workout and does not seems to work either way.
I too am having that issue, have been for awhile actually - though my planned workouts come from AI Endurance.
are you uploading from AIEndurance to Zwift directly? or are those WO transiting through intervals.icu? if first it would mean this is a zwift issue and if latter then it might be an intervals.icu issue.
AI Endurance doesn’t have direct Zwift access. It is going via intervals.icu. My statement was more that workouts pushed into intervals.icu from AI Endurance also experience the same issue while going to Zwift.
This is fixed now. Sorry for the inconvenience and tx for the report. The fix will be deployed on Friday AM.
Actually we just deployed the fix. if you click the RETRY button on failed workouts they should go through.
@david thx can confirm that it works now! have a great weekend!
