Id like to know which FTP is used when doing indoor workout ?
And if I do my workout outdoor how can I set the workout to use the outdoor FTP so the power target is set according to the outdoor FTP ?
This is determined by how you create your workouts.
If you select “Trainer” - then it will use indoor FTP. Otherwise it will be outdoor.
you can always create the workout, then download the JSON or the FIT and look at it yourself to confirm.
Easier / faster to get the info / confirmation.
note: I do not know if there’s a diff when you use the workout type as RIDE vs VIRTUAL RIde
