How do I delete the initial portion of my ride without data?
Is it possible to delete this portion of my ride log without data and all other corresponding data calculations will be updated?
Scroll to the bottom of the activity, click on Actions, then Crop.
The is also an option to ignore a part of the data.
Thanks! Btw I learnt that if the route is uploaded from Strava, you have to crop it in Strava and then click Action>Resync, that worked for me.
Is there a way to do the opposite: delete a section of an activity in the middle? I left my watch running during a strength session while I took a long break and I’d like to delete it and merge the two portions of the activity on either side. The only “delete” I see is to delete an interval, but I want to delete the actual recorded data and exclude it from the workout.
You can use Ignore Part to exclude the data during that period; it’s as simple as highlighting the section that should be ignored.
To crop it, you could use Fitfiletools.com > Section Remove
I just used crop and removed everything but the portion I selected! How do I undo it?
Why does this website make everything so gd complicated?!
