Thank you. It’s what I am still doing. I wonder if it’s possible to have a solution to have everything automatically but it seems to be unpossible for moment.
I guess the answers don’t help so far, because it’s not only about setting up percentages per zone.
I have basically the same requirement using HRR (hear rate reserve) or Karvonen zones (only different names for the same).
The formular is the following: restingHR + (maxHR - restingHR) * zonePercentage
So it should be easy to understand, why it’s currently not possible in intervals.icu to use it. @david would need to implement the calculation, so that the factor applies at the correct position.
Some background why it’s important for me:
after a longer recovery phase about 4 weeks I’m totally out of shape (always crazy to see, how fast detraining kicks in ). It doesn’t make sense to test myself for threshold HR - because I’m not fit enough.
So basic endurance is the key for building up fitness again. For that I usually take HR instead of pace/power, especially for Zone 1 efforts (3 Zone model)
My resting HR really went up by around 10 beats, so Karvonen reflects this and my Zone 1 got reduced, which is what I feel as well.
If I would use one of the templates in intervals.icu, I can just base on either maxHR or THR. maxHR is obiously the same like 4 weeks ago - and THR isn’t realistic, as I already pointed out.
That’s only an obvious use case, showing the difference of both approaches. When I’m back in shape (soon ) then the difference between Karvonen and a “classical” method is quite low.
