I’m having trouble getting the export to Google Calendar to work, I’ve been copying the ICS link from the export option in Intervals. When I add this as a calendar in Gmail it creates a calendar and seems to be linked, however, I can’t get any of the planned sessions to appear in the calendar even if I only have the intervals calendar as the only one selected to display?
I’m assuming it’s operator error, what am I missing?!
Its not user error but a bug in Intervals.icu that I have just fixed. I don’t know how often Google refreshes the calendar. It might take a while for your stuff to show up. Tx for the report.
I added your calendar to my own Google calendar and your rides are now showing up. If you still don’t see anything by the end of the day I can change the URL of your calendar which will force Google to refresh it.
Apologies for reviving the topic - but i think its fitting good in here:
The Google Synchronization is creating an “All day” Event, even if you entered a specific Time while planning in Intervals.icu.
Is it somehow possible to also sync the Entries with planned Time?
would be awesome!
I’m also having trouble seeing interval.icu activities on google calendar. I have added the calendar as a url to select and I tested out adding a planned activity, which did sync, but I’d also like to see completed ones. Is that possible?
