Garmin Wellness Data Selection Not Saving
Hi all,
First off, just want to say a big thanks for all the hard work and the updates recently - really appreciate everything you’re doing to keep improving the platform!
I’ve noticed a possible bug when trying to manage which wellness data fields are automatically imported from Garmin. Specifically, it seems I’m unable to update these settings.
When I open the settings for Garmin wellness data import, I can see all options are checked except for “Resting HR.” If I check that box and click “OK,” it appears to save, but when I refresh the page, the box is unchecked again. The same thing happens in reverse too: if I uncheck other fields, they get re-checked after refreshing.
Because of this, unless I upload a full archive of my Garmin data, Intervals.icu just shows the default placeholder value for Resting HR each day instead of pulling the actual data from Garmin.
I’ve tested this across Firefox on Windows, Safari on iOS, and Opera on Ubuntu, so am fairly sure it’s not a system/browser issue.
I was wondering if anyone else has run into this issue or found a workaround?
Thanks again for all the great work!
Before:
Selecting “Resting HR”:
After selecting “Resting HR”, but before refreshing:
After refreshing:
Yep same problem here. The only difference being that my auto selected ones are weight, kcal and vo2max. If I try to select others, those new selections are lost upon refreshing.
I also mentioned my problem here: Garmin health snapshots supported - #14 by tennisninja
Thanks for turning this into a bug report.
Not sure if a fix was done for this but I just checked it again and it seems to be working now.
Can you confirm?
I have just checked, and it does seem to be working now!
Thank you to the devs for the fix!
