Full model is: MARQ Athlete (Gen 2) 010-02648-40
https://www.garmin.com/en-US/p/783448
All of the MARQ gen2 watches are the same as Epix2 but with an upgraded case, band, and buttons.
Thanks, Iāll add support shortly.
Please note I have moved away from Garmin to Suunto. I have had enough of Garmin not processing 3rd party activities for all of their metrics. I will try to keep this alive with support for future watches though.
1.9 support added for Marq Gen 2 watches.
Thank you! Iāve confirmed I can install it on my watch now and it works nicely. Cheers!
Hi James, I have Forerunner 970, could you please add this model to the compatible watches? Thanks!
Planning it, just need to find some time to add (and test) the new devices.
Support added for:
Vivoactive 6
Forerunner 570 (x2)
Forerunner 970
Hi! Could you add support for Garmin Marq Adventure gen.1? All specs the similar for already supported Fenix 6. Thank you
added
should appear in the next hour or so.
thank you so much!
Hi James,
I think I am affected by the same issue, lately Iāve followed a friend on intervals and I seem to be getting his info.
What do I do to resolve it?
Cheers,
MichaÅ
This was fixed pretty quickly, make sure you have the most recent version.
According to Connect IQ I am on 1.97, just tried to reboot the watch to make sure the glance reloads but for now itās still cached it seems? Tried removing from glances and adding it back and doesnāt seem to change anything. Tried checking the version from the watch itself but Iām getting āVersion: Loadingā.
Is there some way to confirm/force refresh?
Iām on Fenix 7X SS for what itās worth, not sure if that matters at all.
Youāre on the latest, that is indeed very strange. If you add a workout to your calendar, does it appear as the upcoming workout?
Tried that before doing the previous post but nothing so far (XXXX-XX-XX Unknown no activties found). Will try running in an hour or so, will report if that changes anything.
UPDATE: still the same
UPDATE2: After uninstalling completely, reinstalling and connecting again it shows my stuff.
Hi James
Thanks a lot for your widget, Iāve been using it for a year now and itās really practical!
Iāve realized that some watchfaces allow for custom complications linked to 3rd party apps. Iām not sure how hard that could be to implement that, but it would be a really useful feature to be added to your widgetā¦
Do you think you could consider it? Thanks!
This would be cool. Iāll take a look, the problem is I donāt have a Garmin watch myself anymore, so I can only really add stuff that is easy to test and validate using an emulator. If it is simple, Iāll do it!
Thanks for giving it a try, and let me know if I can be of any help!
Any chance you might be able to add a customization for runners? Replace FTP with running VO2 max, or something?
Sorry no, only because I donāt have a Garmin device any more so I am just keeping the existing app going.
