I just noticed this working. Brilliant!
Thanks!!
Hi David,
Today I use trainerday.com to make a workout, they use .TCX files, the question is how can I import this training here, because I have an error when I try to upload
TCX files are not supported (yet). Can you download a zwo or mrc file instead?
Is not possible trainerday only send :TCX and I already try to convert to others format without success.
The solution for me is to reconnect Strava and file come up
Ah so this is a completed activity. I didnât get that.
Duplication issue, in case you want to take a look @david
Intervals.icu Garmin Connect
Intervals.icu Strava
The moving times are very different which is why it hasnât considered them to be the same. The Garmin one doesnât have an altitude trace and he pace chart has less stuff on it. I think Strava is doing some enhancement.
For this kind of thing is probably best to keep both because in this case you might want to keep the Strava activity.
Hi, have another duplicate pair here:
https://intervals.icu/activities/i1082236
https://intervals.icu/activities/5270440083
Any idea why theyâre not treated as one?
I had to reconnect Strava because zwift but now i have duplicated swims activities. Only swim, no runs or bike.
For example.
btw: the % compliance is wrong, i have 1 hour in TrainingPeaks. 147% is way a lot since total time in activity was 1:03:07.
Thanks David
I donât know why that swim is duped. You better just delete the one you donât like.
All of my pool swims are getting duplicated from Strava and Garmin as well. But not my outdoor swims (and not bikes or runs either). Seems like there might be an issue with pool swims?
Here is a screenshot from last week. Red circles are duplicated pool swims, blue circles are both outdoor swims. It happened again in the pool today too. Let me know if I can provide more details to help chase this down?
I awalys delete one data manually
Hmm. I will have a look at that.
Those dups have moving time a little different due to differences in how Strava and Intervals.icu process the files. I had the âis duplicateâ threshold for time and distance on 1%. I have relaxed that to 5% which should sort this out for future. Will deploy Thurs AM.
Hi, Is there a way to manually group activities, if it doesnât happen automatically?
What do you mean by âgroup activitiesâ? If dups are not detected automatically you can delete the one you donât want.
When there is coming the new DFA Alpha1 stuff to intervals.icu, and the HRV data from the original garmin fit file is needed (strava donât push HRV through so far!?) there is a need for me to sync my strava activities (my main app where all is in) as i do now + garmin activities or may just the HRV data from garmin.
Hope so much that this will work then đ¤ˇđź
⌠and of course that DFA Alpha1 is coming
I do have the DFA a1 stuff on the todo list and Intervals.icu is already extracting the HRV data from .fit files. So you will need to get your activities from Garmin Connect and not Strava (or as well as Strava). I canât say when it will be done unfortunately.
Ok thanks, great. ⌠but arenât there then 2 activities instead of 1 in my calender, when i connect to garmin + strava?
Sorry, yeah I meant delete-except doesnât it now link to both Strava & Garmin Connect, too (as part of the duplicate handling process)?
