Hi
Anyone using the Fourth Frontier HRM ?
I have it on evaluation and can’t decide if I want to keep it.
I would welcome the view of any users who are using it or trilled it with intervals.icu
Hi
Hi @segovia , I had a good look at it and reviewed it here: Fourth Frontier X2 review. It’s a good product but perhaps only for the right kind of people.
If you are over 40/50 then its ST segment metric for heart strain is novel and might add an early warning signal for you.
you’ll be getting an ECG at exercise levels of intensity, when i had one a few years back it was a walking ramp test and i don’t think i got much above z1.
if you want a tool that helps you monitor yourself and family members (elderly parents) then it gives you some extra data points to help facilitate consultations with your doctor. the pdf charts are particularly good for that.
if you are a biohacker then it gives you more data points than you might otherwise get.
it’s not ant+ and only have one BLE connection from memory
it’s not cheap and you could replicate much of the features with a polar h10 and, kubios or something similar (there are still costs there). but Fourth Frontier gives a complete working solution out of the box.
Thanks, I came across your review before I purchased, and it did steer me towards the device. My main gripe is support does not respond to emails and the user forum is very quiet for 11,000 users. One of my posts has been stuck in moderation for 5 days.
I have also seen some latency on Trainer road, HRM goes from 120 to 88 for an example. My Kickr is ANT+ and I had a cadence device which was on Bluetooth but isn’t needed as the Kickr has cadence. I was thinking it could be a Bluetooth clash, I have removed it and wil test again.
hey there.
I extensively tested the raw HR and you saw the results on the review. so it was pretty good. in that respect.
There was, from memory, a bit of latency (by that I mean a multi-second LAG) but I was unsure if that was because of the multiple devices in use.
Perhaps a more likely cause of interference is with your WiFi (I wrote a piece on that last week by coincidence, but I won’t push my luck and post another link in this thread!!)
I don’t get immediate responses from support but it was either within 24 hours or 48 hours. I don’t know if I’m flagged up as a reviewer and get preferential responses??? I don’t think so in this company’s case.
Thanks, I tested again this evening and the latency seems to have disappeared. I used two HRM’s one on Bluetooth and the other Ant+, I had Trainerroad and my Hammerhead GPS running and both were reporting identical HRM +/- 1 BPM.
It would be nice if the HRM data could be exported PR, QR and QRS, do you know if that’s possible ? Numbers are easier to analyse compared to graphs.
Hey, not sure if this thread is still active, but wanted to leave my thoughts here.
I am a medical doctor and bought a fourth frontier device as I was experiencing palpitations and wanted to have closer monitoring. You can record a 1-lead ECG for up to one hour or up to 24h in an activity. However, activity recording never worked for me - data just didn’t get saved. Upon contacting support, they told me the device is broken, however the warranty period had already ended. Considering the hefty price tag, this was quite disappointing…
Medically speaking, the graphs cannot be “scrolled through”, you can only see a fixed 20 sec interval. This is very inconvenient as the graph on both edges is not clearly visible. PQ/QRS/QT times are not automatically calculated and cannot be read easily from the graph as it doesn’t use standard plotting. Also, metadata cannot be exported, e.g. to replace 24h monitoring.
Overall, I was disappointed. Great device, but broke after a few uses, and there were so many inconsiderate oversights in terms of data visualization and analysis tools. It does deliver accurate HR monitoring but you can also get a much cheaper device with similarly reliable results.
anyone used this to utilise the breathing side of things instead of Tymewear? Looks like it calculates VT1/VT2 and VO2 and you can have alarms if you go above or below any breathing targets you set.
