Need some advice on how to juggle two sports without ending up back in PT.
Quick background: I did track for about 7 years. My best times were around 17:00 for a 5k and 35:00 for a 10k, so I’ve got some speed, but my body always seemed to hit a wall. Every time I got into peak shape, I’d get sidelined with an injury.
I actually started cycling because of my last injury and totally fell in love with it. It’s wild being able to put in 12–16 hours a week without feeling like my legs are literally falling apart.
I’m fully recovered now and really want to get back to running fast, but I don’t want to give up the bike. My thought is to keep the high volume on the bike to keep my fitness up, and then just do “key” run sessions to keep the legs snappy and maintain that VO2 max.
I’d love to hire a coach, but I’m still finishing my studies and the bank account says no for now.
Has anyone here successfully balanced both? How many days a week should I actually run if I’m doing that much volume on the bike? Any tips on avoiding the “running injury cycle” while staying fast would be awesome.
I am primarily a cyclist and use a plan to train for my racing on a bike, but I would suggest looking at duathlon training plans. While you may not be aiming to do both sports together as in their events, the balance between the two disciplines would be similar and could give you a framework.
I would also suggest giving one of the various AI coaching tools that are being discussed here a go. I am using IcuSync myself to develop plans and to evaluate my performance after I complete workouts.
Using Claude, I asked the model to assess what capabilities and limitations would apply to a multi-sport training plan and how it would approach developing a plan for an athlete who uses Intervals:
I am also interested in this. I am a noob myself to the bike, and also just using it to supplement running for now. Over the last few years I’ve trained solely running mostly in the 40-80mpw range (65-130km per week) with 2-3 running workouts each week.
Recently I’ve dropped the running volume significantly to about 25-35 miles per week, consisting of almost entirely of quality sessions. I’ll typically shoot for an LT1 or LT2 session of 6-10mi worth of fast running, a speed session with 2-3mi of Mile paced running, and a light vo2 session of 3ish miles of vo2 stimulus.
I’m essentially just plugging the bike in on easy days and racking up easy aerobic load. It seems to work well so far, but my legs have been getting pretty trashed on the long LT days, where I think the decreased mileage is really starting to affect my durability or stiffness… not sure
If you’re cycling in any decent amount a lot of that fitness translates to running. I was sidelined from running for 8 months and when I returned my running fitness was actually better. I think a lot of this comes down to the sheer volume of cycling you can tolerate vs running, you can accumulate a huge amount of a suboptimal stimulus. Of course if I was running consistently for those 8 months instead I would have seen more improvements to running.
I then continued to have flareups of previous injuries (achilles and patella) due to load mismatch because my fitness was beyond what my tissues could handle. My physiotherapist told me I should only be doing short easy runs on flat ground or treadmill, so I do a 15 minute easy run to work for now and will probably continue this for months.
Your situation resonates a lot — I’ve been dealing with recurring (chronic) lower limb injuries myself and it pushed me to think more carefully about load management across different sports, not just running volume alone.
The core issue you’re describing is something speedophile touched on: your cardiovascular fitness can outpace your tissue tolerance. The bike keeps your aerobic engine humming, but your tendons, bones and cartilage adapt much more slowly than your VO2max. So when you add running back, you’re essentially a well-trained engine in an undertrained chassis — which is exactly when injuries happen.
A few things that have helped me think about this:
Track sport-specific load, not just overall load. Generic ATL/CTL includes your cycling volume, which is mostly cardiovascular stress with minimal lower limb impact. Running, strength,… — these create fundamentally different mechanical stress. I’ve been building a custom Lower Limb Stress Score (LLSS) in Intervals.icu that weights each sport by its actual joint loading (running = 1.0 reference, cycling = 0.20, elliptical = 0.60, strength lower body = 0.75, etc.) and then plots an ACWR specifically for lower limb load. That way you can see if your running load is ramping too fast relative to your tissue baseline — even if your overall fitness chart looks fine.
On the cycling/running balance: your instinct is right — high bike volume + key run sessions is a valid approach. Most of the duathlon and hybrid training literature suggests 3 quality run sessions per week is sufficient to maintain running-specific neuromuscular sharpness when aerobic base is already high from cycling. The temptation is to add more running because it feels manageable — resist that, especially in the first 8–12 weeks back.
Running dynamics matter more than pace when returning. Ground contact time, cadence and vertical ratio are early indicators of compensatory patterns that precede injury. If you have a Garmin chest strap (HRM-Pro), I’d track these from day one rather than waiting for pain to appear.
I’ve put these tools together as public custom scripts and charts in Intervals.icu — you can find them on my profile. The LLSS script covers 45+ sport types automatically, and there’s also a Running Dynamics Dashboard if you have a Garmin HRM-Pro chest strap. Happy to answer any questions if something doesn’t work as expected on your setup.
Good luck — sounds like you have the right mindset going in.
Thanks for the tips! I’ve been using ChatGPT as my coach since I started, and it’s been solid, but man… inputting all that data manually is a total drag. I really need to stop being lazy and figure out that Intervals API.
one problem form me about using AI as coach is it being a “yes man.” some times haha
The duathlon plan idea is actually smart—I’ll definitely check out that Claude link.
Since you’re using IcuSync, is it easy to link up? I’d love to know if it saves you from that manual data entry nightmare.
Thanks for the input! Since I’m sticking to 5k and 10k for now, I’m hoping those 3 key sessions will get me to a PB without needing massive mileage—definitely trying to avoid the “broken legs” phase.
First week back is done! That first day was a killer, but the body is finally starting to remember how to run. Honestly, I feel like sub-40 is already there, but I’m gonna be smart and cap it at 20km a week for the next couple of months. Not much, but like you said, better than a flare-up!
Since you went through those Achilles issues, are there any specific rehab exercises you swear by, or are you literally just sticking to the short treadmill runs for now because I had some Achilles problem just been doing while stretching some strengthening exercises with bands.
Thanks for the breakdown! The ‘big engine in an undertrained chassis’ thing makes total sense. I’ve been lucky enough to avoid running with actual pain, but I definitely deal with those annoying little inflammations if I overdo the impact. Even if the engine feels good, I’m definitely not trying to force it this time.
I’m for sure going to check out your LLSS script and the Running Dynamics Dashboard on Intervals.icu. Tracking the mechanical stress separately from general fitness sounds like exactly what I need to keep those inflammations away. I’ve also been doing some resistance band exercises to help prep my legs for the impact.
Ready to settle some ‘undone business’ on the track, just a bit smarter this time!
Since I’m already on Intervals.icu, what’s the easiest way to find your profile so I can add those custom charts?
For sure way better to play it safe. The main exercise he has me doing is weighted single leg calf raises. He wants me fatiguing around 8 reps and it’s ok for my achilles to be in a bit of pain afterwards, but I stop if it’s super painful during the reps. Maxing out at 8 reps for a calf raise takes a ton of weight, I have a backpack I put plates in and I use a step to get more range of motion.
I still get flare-ups seemingly at random, like when I go for a walk on my lunch break it can flare up and that will last for a few days where I have to walk flat footed lol. But it’s better. Afaik progressive loading with calf raises and short runs is best practice rehab for achilles, my physio says to go through the range of motion but many say to do the calf raise as an isometric hold for time instead.
Getting the data to the LLM is the big step - manually doing it and setting the context is rough so using a MCP that can integrate will make your life a lot easier.
IcuSync is really easy to connect to Intervals - Toby has done an excellent job of explaining the process and capabilities here: https://icusync.icu/
Great to hear the mindset is right this time — smart beats hard every time coming back from a history of inflammations
To find the activity fields and charts:
— Activity Custom field (LLSS calculation): Custom → Activity Custom Scripts → Browse shared → search “Lower Limb Stress Score”
— Activity Charts (Running Dynamics Dashboard + LLSS Risk Gauge): open any activity → Custom → Activity Charts → browse existing → search “Running Dynamics” or “LLSS Risk Gauge”
— Fitness Chart (the PMC with the 3 lines + coloured zones): go to your Fitness tab → add a custom chart → browse shared → search “Lower Limb Load Management Chart”
Install in that order — the charts depend on the fields being active first.
A few practical notes for your setup specifically:
The LLSS script works for everyone out of the box — it auto-detects sport type and reads your body weight from your wellness log if you have it filled in. No HRM-Pro needed.
The Running Dynamics Dashboard only adds value if you have a Garmin HRM-Pro or HRM-Pro Plus chest strap. Without it you’ll get no running dynamics data from Garmin, so skip that one for now if you don’t have it.
Given your background (track, high fitness, returning from inflammation history), the most useful thing to watch on the LLSS chart is the LL Form line — specifically the first 8 weeks as you add running back on top of your cycling base. Your aerobic fitness will make the sessions feel easy, but the Form line will show you if your tissue load is climbing faster than your 42-day baseline. That’s the signal to respect even when your legs feel fine.
The 20 km cap is right. Three runs alongside 12-16 h of riding works, but not all hard while the Achilles settles: two easy 25-35 min runs (strides after one) plus one threshold session; add intervals once it has been quiet for 3-4 weeks. The bike carries the aerobic side.
Change one variable a week (volume or intensity), and progress on how the Achilles feels next morning, not how the session felt.
Alongside speedophile’s single-leg calf raises, add a bent-knee version (soleus takes the biggest running load). Don’t switch to a lower-drop or racing shoe while adding speed. If it grumbles after rides, check saddle height and try cleats rearward.
Since you use ChatGPT as a coach: I built Smash Coach (smashcoach.app). It’s a fittness coach for hybrid athletes, and it plans running and cycling in one week around your available days and any injury you flag, and rebuilds when those change.
