I have added a ramp rate plot which is fitness today - fitness 7 days ago. Also added a 7 day moving average (default for ramp rate) and 42 day moving average.
Compatible bars now stack. Currently this only happens for the “Sieler” zone plots (Z1+2 etc.). If you already have a chart with these on you need to remove and re-add them to see the stacking.
This is really great!!
Could there be the possibility to add a horizontal line to these custom plots. As an example: I have goal of reaching 250 km per week, and it would be great to see a horizontal line in the custom distance graph, to see which weeks I’ve reached this goal.
Thats a good idea. I will try fit it in. Busy adding filtering for activity types and so on.
You can now filter the activities used for a plot and change the axis label. This one is showing time spent running. Going to do plot colours and so on tonight.
Awesome stuff. Any thoughts on having the ability to re-order the charts?
MIke
Hello, this is a great addition!
When you make a custom chart of the Z1-2 / Z3-4 / Z5 it shows the time in each of these. Is it possible to change this to a % of time when you hover?
Thanks for all the great work!
Yes I will add re-ordering.
Thanks. I will look into the % thing for stacked charts. Would be nice to have a solution that doesn’t require hover for iPads and so on.
Hi David, is it possible to set somewhere the “time in zones” chart with % instead of total time?
thanks!
Awesome.
The colour picker now includes swatches for all the standard colours as well as any extras on your charts.
Nice work, this website is better and better.
Can we sort the zones the other way, so we can have Z1+2 at the bottom, Z3-4, and then Z5+ like in 30s power graph, i think it is more logical
Thank you.
You can already do that if you set up a custom chart rather than use the built in one, adding the zones in the reverse order.
Here’s mine for daily and weekly totals:
Mike
oh, thank you, exactly what i wanted
Mike_Lauder: thanks – good tip!
Sweet.
How did you get the Quarantine/Build/Rest labels to show?
