Correct setting of zone
Hi there,
Starting telling I’m a newby in the running world; after years of swim and gym, 1 years ago i started my journey in the running world, i used to run with my phone in the hand form june to jenuary recording the train activities on strava; than i bought a garmin forerunner255 and started recording also HR and the correct pace of my trains.
rn i tried to set a plan for a 10k in december and a 21k in March using intervals coach after months of garmin coach plans and Runna. So i noticed that for the itervals plan, the treshold pace is slower than the garmin one, i uploaded on intervals.icu all the previous trains giving it alll the garmin and strava archivies. Do you suggest to use the garmin treshold pace and modifing it manually on intervals or starting to refere to the new one?
thanks for the answer
I would not automatically replace the Intervals threshold pace with the Garmin number just because Garmin is faster. They are estimates produced from different data and algorithms, so some disagreement is normal.
The better question is which one matches what you can actually sustain. Threshold pace should feel hard but controlled, roughly the pace you could hold for around 45 to 60 minutes when fresh. If the Garmin value came from a proper threshold test or it lines up well with your recent 5K or 10K performances, I would use that as the starting point. If it is just an automatic estimate, I would be more cautious.
Since you are still relatively new to running, I would actually prefer being slightly conservative at first. Run a few threshold sessions using the Intervals value and look at pace, heart rate and perceived effort. If you are finishing comfortably and the pace clearly feels too easy, move it up gradually.
The goal is not to make Garmin and Intervals agree. It is to set a threshold pace that reflects your current fitness and lets you complete the work consistently without turning every threshold session into a race.
I have always used the Garmin threshold pace calculated, and then input that into Intervals Run Pace Settings “Threshold Pace” field. Is that wrong approach?
thanks for the answer.
yes, i think i will follow the intervals.icu threshold pace, i stopped hard train in agoust for holiday and only runned 5/10km a week, so it seems to me that intervals made a “live calculation” of my performance so it could be better in order to reach a better performance during the races and not beeing there whith a fatigue excess. I was scared of yesterday easy pace for a 48 min easy run (like 8min/km with a garmin thershold of 4:10) that’s the why of tha question.
thans again
Hi there,
If you want to use some trainingzones and be sure you’re training at the right intensity to get better, i might have you need. We build a program using Intervals data to make you train metabolicly correct. You can do testing as much as you want, with or without lactate. The engine shows you what testing suits you the most for your goal and with those results you can be sure you make progress with your training. Even more, the program can calculate how much you need to fuel to reach your goal. I really hope you can be succesfull with your 10k an 1/2 Marathon!
Incase you want to try it: Here is the betacode you can use (BREAKOUT-5PJ6-CJ69) , if there are question you can always DM me!
app.breakout.training
thanks mate, i will give it a try
